[MOAB-dev] r4498 - in MOAB/trunk: . tools/mbzoltan
kraftche at cae.wisc.edu
Wed Feb 16 09:52:48 CST 2011
Author: kraftche
Date: 2011-02-16 09:52:48 -0600 (Wed, 16 Feb 2011)
New Revision: 4498
Added:
MOAB/trunk/tools/mbzoltan/mbpart.cpp
Removed:
MOAB/trunk/tools/mbzoltan/mbzoltan.cpp
Modified:
MOAB/trunk/configure.ac
MOAB/trunk/tools/mbzoltan/Makefile.am
Log:
merge changes from Version4.0 branch
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2011-02-16 15:49:13 UTC (rev 4497)
+++ MOAB/trunk/configure.ac 2011-02-16 15:52:48 UTC (rev 4498)
@@ -609,6 +609,10 @@
# build variables.
if test "xyes" = "x$WITH_ZOLTAN"; then
+ if test "xyes" != "x$WITH_MPI"; then
+ AC_MSG_ERROR([Cannot include Zoltan support without MPI. See --with-mpi])
+ fi
# Test for zoltan headers
AC_LANG_PUSH([C++])
old_CPPFLAGS="$CPPFLAGS"
@@ -647,7 +651,7 @@
[unset ac_cv_lib_zoltan_Zoltan_LB_Partition
AC_CHECK_LIB([zoltan],[Zoltan_LB_Partition],
[ZOLTAN_LIBS="-lzoltan -lparmetis -lmetis"],
- [AC_MSG_ERROR("libzoltan not found in $ZOLTAN_LIB_FLAGS")],
+ [AC_MSG_ERROR([zoltan library not found or not usable. Perhaps you need to specify --with-parmetis=@<:@DIR@:>@?])],
[-lparmetis -lmetis])])
LDFLAGS="$old_LDFLAGS"
Modified: MOAB/trunk/tools/mbzoltan/Makefile.am
--- MOAB/trunk/tools/mbzoltan/Makefile.am 2011-02-16 15:49:13 UTC (rev 4497)
+++ MOAB/trunk/tools/mbzoltan/Makefile.am 2011-02-16 15:52:48 UTC (rev 4498)
@@ -12,9 +12,8 @@
libmbzoltan_la_SOURCES = MBZoltan.cpp
libmbzoltan_la_include_HEADERS = MBZoltan.hpp
-bin_PROGRAMS = mbzoltan mbpart
+bin_PROGRAMS = mbzoltan
LDADD = libmbzoltan.la
-mbzoltan_SOURCES = mbzoltan.cpp
-mbpart_SOURCES = mbpart.cpp
+mbzoltan_SOURCES = mbpart.cpp
Deleted: MOAB/trunk/tools/mbzoltan/mbpart.cpp
--- MOAB/trunk/tools/mbzoltan/mbpart.cpp 2011-02-16 15:49:13 UTC (rev 4497)
+++ MOAB/trunk/tools/mbzoltan/mbpart.cpp 2011-02-16 15:52:48 UTC (rev 4498)
@@ -1,11 +0,0 @@
-#include <iostream>
-#include <sstream>
-#include <stdlib.h>
-#include <list>
