[MOAB-dev] r4487 - MOAB/trunk/tools/dagmc
    bmsmith6 at wisc.edu
    Thu Feb 10 18:44:57 CST 2011
Author: bmsmith
Date: 2011-02-10 18:44:56 -0600 (Thu, 10 Feb 2011)
New Revision: 4487
Modified:
   MOAB/trunk/tools/dagmc/DagMC.cpp
Log:
-Fix incorrect comments in point_in_volume test. Code was correct but comments were wrong.
-Simplify negative ray length used for overlapping geometry.
-Consistently use nonneg_ray_length and neg_ray_length in ray_fire.
Passes make check. Better tests of overlap logic are in progress.
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp	2011-02-08 19:51:57 UTC (rev 4486)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp	2011-02-11 00:44:56 UTC (rev 4487)
@@ -67,11 +67,9 @@
                    of results
    Overlap Thickness:
-   This tolerance is the maximum normal distance between two overlapping
-   volumes. This should be zero unless geometry has overlaps. User must provide
-   guidance about the magnitude of overlaps. Overlap thickness depends upon
-   geometric model and must be small enough not to significantly affect physics.
-   For CAD models, 0.1 cm is suggested.
+   This tolerance is the maximum distance across an overlap. It should be zero
+   unless the geometry has overlaps. The overlap thickness is set using the dagmc
+   card. Overlaps must be small enough not to significantly affect physics.
      Performance: increasing tolerance decreases performance
      Robustness:  increasing tolerance increases robustness
      Knowledge:   user must have intuition of overlap thickness
@@ -583,48 +581,28 @@
     prev_facets.clear();
+  // check behind the ray origin for intersections
   double neg_ray_len;
-  // no overlaps
   if(0 == overlapThickness) {
     neg_ray_len = -numericalPrecision;
-  // overlaps
   } else {
-    // If the previous facet (surface) is unknown, use large neg_ray_len.
-    // Although an overlap does not occur after a collision, it may occur after
-    // a particle starts on a surface (cell-based weight windows).
-    if(prev_facets.empty()) {
-      neg_ray_len = -100*overlapThickness;
-    // if the previous facet is known, use the angle made with the normal
-    } else {
-      // get coords of prev facet
-      const EntityHandle* conn;
-      int len;
-      CartVect coords[3], normal;
-      rval = MBI->get_connectivity( prev_facets.back(), conn, len );
-      if (MB_SUCCESS != rval || len != 3) return MB_FAILURE;
-      rval = MBI->get_coords( conn, len, coords[0].array() );
-      if (MB_SUCCESS != rval) return rval;
-      // get normal of prev facet
-      coords[1] -= coords[0];
-      coords[2] -= coords[0];
-      normal = coords[1] * coords[2];
