[MOAB-dev] buildbot failure in Fathom on moab-par
moab-dev at mcs.anl.gov
Tue Jan 18 00:08:29 CST 2011
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/395
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
rank 1 in job 659 gnep.mcs.anl.gov_36928 caused collective abort of all ranks
exit status of rank 1: killed by signal 6
FAIL: uber_parallel_test
PASS: scdtest
Warning: acis file has sequence numbers!
PASS: pcomm_serial
Running test_write_elements ...
Running test_write_shared_sets ...
Running test_var_length_parallel ...
Running test_read_elements ...
Running test_read_elements_by_rank ...
Running test_read_tags ...
Running test_read_global_tags ...
Running test_read_sets ...
PASS: parallel_hdf5_test
PASS: mhdf_parallel
01: 0.00: Generating mesh
01: 0.00: Resolving shared entities
01: 0.01: Beginning parallel write
00: 0.01: Generating mesh
00: 0.01: Resolving shared entities
00: 0.02: Beginning parallel write
Using default interval count: 2
00: 0.02: Removing written file
00: 0.02: Finalizing MPI
01: 0.02: Finalizing MPI
Wrote 16 hexes in 0 seconds.
Wall time: generate: 0.00061202, resovle shared: 0.00164008, write_file: 0.0194759
PASS: parallel_write_test
2 of 8 tests failed
sincerely,
-The Fathomatic
