[MOAB-dev] r4452 - MOAB/trunk/src/parallel
hongjun at mcs.anl.gov
Mon Jan 17 17:36:47 CST 2011
Author: hongjun
Date: 2011-01-17 17:36:47 -0600 (Mon, 17 Jan 2011)
New Revision: 4452
Modified:
MOAB/trunk/src/parallel/ParallelComm.cpp
Log:
o Added "get_remote_handles" call in "pack_sets" function
o to get remote handles of entities in the set
o Range packing is removed because remote handles are not packed by range
Modified: MOAB/trunk/src/parallel/ParallelComm.cpp
--- MOAB/trunk/src/parallel/ParallelComm.cpp 2011-01-15 17:37:19 UTC (rev 4451)
+++ MOAB/trunk/src/parallel/ParallelComm.cpp 2011-01-17 23:36:47 UTC (rev 4452)
@@ -2399,26 +2399,19 @@
PACK_VOID(buff->buff_ptr, &options[0], all_sets.size()*sizeof(unsigned int));
// vectors/ranges
+ std::vector<EntityHandle> entities_vec(entities.size());
+ std::copy(entities.begin(), entities.end(), entities_vec.begin());
for (rit = all_sets.begin(), i = 0; rit != all_sets.end(); rit++, i++) {
- Range set_range;
- if (options[i] & MESHSET_SET) {
- Range set_range;
- result = mbImpl->get_entities_by_handle(*rit, set_range);
- RRA("Failed to get set entities.");
- buff_size = RANGE_SIZE(set_range);
- buff->check_space(buff_size);
- PACK_RANGE(buff->buff_ptr, set_range);
- else if (options[i] & MESHSET_ORDERED) {
- members.clear();
- result = mbImpl->get_entities_by_handle(*rit, members);
- RRA("Failed to get entities in ordered set.");
- buff->check_space(members.size()*sizeof(EntityHandle)+sizeof(int));
- PACK_INT(buff->buff_ptr, members.size());
- PACK_EH(buff->buff_ptr, &members[0], members.size());
+ members.clear();
+ result = mbImpl->get_entities_by_handle(*rit, members);
+ RRA("Failed to get entities in ordered set.");
+ result = get_remote_handles(store_remote_handles, &members[0],
+ &members[0], members.size(),
+ to_proc, entities_vec);
+ RRA("Failed in get_remote_handles.");
+ buff->check_space(members.size()*sizeof(EntityHandle)+sizeof(int));
+ PACK_INT(buff->buff_ptr, members.size());
+ PACK_EH(buff->buff_ptr, &members[0], members.size());
// pack numbers of parents/children
unsigned int tot_pch = 0;
@@ -2452,8 +2445,6 @@
assert(members.size() == tot_pch);
if (!members.empty()) {
- std::vector<EntityHandle> entities_vec(entities.size());
- std::copy(entities.begin(), entities.end(), entities_vec.begin());
&members[0], &members[0],
