[MOAB-dev] buildbot failure in Fathom on moab-shared
moab-dev at mcs.anl.gov
Wed Jan 12 11:09:07 CST 2011
The Fathomatic has detected a failed build of moab-shared on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/moab-shared/builds/342
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The web-page 'rebuild' button was pressed by 'jvporter': Testing rebuild...
Build Source Stamp: 4435
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
Running test_getEntArrAdj_up ...
Running test_getEntArrAdj_down ...
Running test_getEntArrAdj_invalid_size ...
Running test_getEntArrAdj_none ...
Running test_existinterface ...
*** glibc detected *** /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests: double free or corruption (out): 0x00007fff9a4e92b0 ***
======= Backtrace: =========
/lib/libc.so.6[0x2b56764ce0ea]
/lib/libc.so.6(cfree+0x8c)[0x2b56764d1c7c]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/libiMesh.so.0(imesh_dtor_+0xf)[0x2b56756822ff]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests[0x404601]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests[0x4026e4]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests[0x402b20]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2b56764781c4]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests(__gxx_personality_v0+0x79)[0x4020d9]
======= Memory map: ========
00400000-00408000 r-xp 00000000 09:00 7569987 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests
00608000-00609000 rw-p 00008000 09:00 7569987 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests
00609000-00673000 rw-p 00609000 00:00 0 [heap]
2b567545d000-2b567547a000 r-xp 00000000 08:01 685786 /lib/ld-2.7.so
2b567547a000-2b567547d000 rw-p 2b567547a000 00:00 0
2b567567a000-2b567567c000 rw-p 0001d000 08:01 685786 /lib/ld-2.7.so
2b567567c000-2b5675692000 r-xp 00000000 09:00 7569945 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/libiMesh.so.0.0.0
2b5675692000-2b5675891000 ---p 00016000 09:00 7569945 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/libiMesh.so.0.0.0
2b5675891000-2b5675892000 rw-p 00015000 09:00 7569945 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/libiMesh.so.0.0.0
2b5675892000-2b5675a90000 r-xp 00000000 09:00 7569938 /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2b5675a90000-2b5675c90000 ---p 001fe000 09:00 7569938 /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2b5675c90000-2b5675c99000 rw-p 001fe000 09:00 7569938 /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2b5675c99000-2b5675c9b000 rw-p 2b5675c99000 00:00 0
2b5675cbe000-2b5675cbf000 rw-p 2b5675cbe000 00:00 0
2b5675cbf000-2b5675dae000 r-xp 00000000 08:01 360647 /usr/lib/libstdc++.so.6.0.9
2b5675dae000-2b5675fae000 ---p 000ef000 08:01 360647 /usr/lib/libstdc++.so.6.0.9
2b5675fae000-2b5675fb4000 r--p 000ef000 08:01 360647 /usr/lib/libstdc++.so.6.0.9
2b5675fb4000-2b5675fb7000 rw-p 000f5000 08:01 360647 /usr/lib/libstdc++.so.6.0.9
2b5675fb7000-2b5675fca000 rw-p 2b5675fb7000 00:00 0
2b5675fca000-2b567604a000 r-xp 00000000 08:01 326565 /lib/libm-2.7.so
2b567604a000-2b5676249000 ---p 00080000 08:01 326565 /lib/libm-2.7.so
2b5676249000-2b567624b000 rw-p 0007f000 08:01 326565 /lib/libm-2.7.so
2b567624b000-2b5676258000 r-xp 00000000 08:01 692969 /lib/libgcc_s.so.1
2b5676258000-2b5676458000 ---p 0000d000 08:01 692969 /lib/libgcc_s.so.1
2b5676458000-2b5676459000 rw-p 0000d000 08:01 692969 /lib/libgcc_s.so.1
2b5676459000-2b567645a000 rw-p 2b5676459000 00:00 0
2b567645a000-2b56765b2000 r-xp 00000000 08:01 685789 /lib/libc-2.7.so
2b56765b2000-2b56767b2000 ---p 00158000 08:01 685789 /lib/libc-2.7.so
2b56767b2000-2b56767b5000 r--p 00158000 08:01 685789 /lib/libc-2.7.so
2b56767b5000-2b56767b7000 rw-p 0015b000 08:01 test_existinterface: TERMINATED (signal 6)
7 tests registered
7 tests selected
6 of 7 tests passed
1 of 7 tests FAILED
sincerely,
-The Fathomatic
