[MOAB-dev] buildbot failure in Fathom on moab-shared
moab-dev at mcs.anl.gov
Wed Jan 12 01:21:14 CST 2011
The Fathomatic has detected a failed build of moab-shared on Fathom.
Full details are available at:
http://gnep.mcs.anl.gov:8010/builders/moab-shared/builds/341
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason:
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
Running test_getEntArrAdj_up ...
Running test_getEntArrAdj_down ...
Running test_getEntArrAdj_invalid_size ...
Running test_getEntArrAdj_none ...
Running test_existinterface ...
*** glibc detected *** /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests: double free or corruption (out): 0x00007fff5ff0b890 ***
======= Backtrace: =========
/lib/libc.so.6[0x2b470cf850ea]
/lib/libc.so.6(cfree+0x8c)[0x2b470cf88c7c]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/libiMesh.so.0(imesh_dtor_+0xf)[0x2b470c1392ff]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests[0x404601]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests[0x4026e4]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests[0x402b20]
/lib/libc.so.6(__libc_start_main+0xf4)[0x2b470cf2f1c4]
/disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests(__gxx_personality_v0+0x79)[0x4020d9]
======= Memory map: ========
00400000-00408000 r-xp 00000000 09:00 7569987 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests
00608000-00609000 rw-p 00008000 09:00 7569987 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/lt-MOAB_iMesh_unit_tests
00609000-00673000 rw-p 00609000 00:00 0 [heap]
2b470bf14000-2b470bf31000 r-xp 00000000 08:01 685786 /lib/ld-2.7.so
2b470bf31000-2b470bf34000 rw-p 2b470bf31000 00:00 0
2b470c131000-2b470c133000 rw-p 0001d000 08:01 685786 /lib/ld-2.7.so
2b470c133000-2b470c149000 r-xp 00000000 09:00 7569945 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/libiMesh.so.0.0.0
2b470c149000-2b470c348000 ---p 00016000 09:00 7569945 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/libiMesh.so.0.0.0
2b470c348000-2b470c349000 rw-p 00015000 09:00 7569945 /disk/itaps-buildslave/moab-shared/build/itaps/imesh/.libs/libiMesh.so.0.0.0
2b470c349000-2b470c547000 r-xp 00000000 09:00 7569938 /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2b470c547000-2b470c747000 ---p 001fe000 09:00 7569938 /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2b470c747000-2b470c750000 rw-p 001fe000 09:00 7569938 /disk/itaps-buildslave/moab-shared/build/src/.libs/libMOAB.so.0.0.0
2b470c750000-2b470c752000 rw-p 2b470c750000 00:00 0
2b470c775000-2b470c776000 rw-p 2b470c775000 00:00 0
2b470c776000-2b470c865000 r-xp 00000000 08:01 360647 /usr/lib/libstdc++.so.6.0.9
2b470c865000-2b470ca65000 ---p 000ef000 08:01 360647 /usr/lib/libstdc++.so.6.0.9
2b470ca65000-2b470ca6b000 r--p 000ef000 08:01 360647 /usr/lib/libstdc++.so.6.0.9
2b470ca6b000-2b470ca6e000 rw-p 000f5000 08:01 360647 /usr/lib/libstdc++.so.6.0.9
2b470ca6e000-2b470ca81000 rw-p 2b470ca6e000 00:00 0
2b470ca81000-2b470cb01000 r-xp 00000000 08:01 326565 /lib/libm-2.7.so
2b470cb01000-2b470cd00000 ---p 00080000 08:01 326565 /lib/libm-2.7.so
2b470cd00000-2b470cd02000 rw-p 0007f000 08:01 326565 /lib/libm-2.7.so
2b470cd02000-2b470cd0f000 r-xp 00000000 08:01 692969 /lib/libgcc_s.so.1
2b470cd0f000-2b470cf0f000 ---p 0000d000 08:01 692969 /lib/libgcc_s.so.1
2b470cf0f000-2b470cf10000 rw-p 0000d000 08:01 692969 /lib/libgcc_s.so.1
2b470cf10000-2b470cf11000 rw-p 2b470cf10000 00:00 0
2b470cf11000-2b470d069000 r-xp 00000000 08:01 685789 /lib/libc-2.7.so
2b470d069000-2b470d269000 ---p 00158000 08:01 685789 /lib/libc-2.7.so
2b470d269000-2b470d26c000 r--p 00158000 08:01 685789 /lib/libc-2.7.so
2b470d26c000-2b470d26e000 rw-p 0015b000 08:01 test_existinterface: TERMINATED (signal 6)
7 tests registered
7 tests selected
6 of 7 tests passed
1 of 7 tests FAILED
sincerely,
-The Fathomatic
