[MOAB-dev] buildbot failure in Fathom on moab-distcheck
moab-dev at mcs.anl.gov moab-dev at mcs.anl.gov
Fri Dec 17 00:11:17 CST 2010
The Fathomatic has detected a failed build of moab-distcheck on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-distcheck/builds/352
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed compile
LOG EXCERPT:
	    (cd $subdir && \
	      make  \
	        top_distdir="$top_distdir" \
	        distdir="$distdir/$subdir" \
		am__remove_distdir=: \
		am__skip_length_check=: \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[4]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/src/io/mhdf'
make[3]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/src/oldinc'
make[2]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/MeshFiles'
list='unittest'; for subdir in $list; do \
	  if test "$subdir" = .; then :; else \
	    test -d "/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/$subdir" \
	    || /bin/mkdir -p "/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles && pwd`; \
	    top_distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /disk/itaps-buildslave/moab-distcheck/build/moab-4.99 && pwd`; \
	    (cd $subdir && \
	      make  \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[3]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/MeshFiles/unittest'
list='io'; for subdir in $list; do \
	    test -d "/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/unittest/$subdir" \
	    || /bin/mkdir -p "/disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/unittest/$subdir" \
	    || exit 1; \
	    distdir=`CDPATH="${ZSH_VERSION+.}:" && cd /disk/itaps-buildslave/moab-distcheck/build/moab-4.99/MeshFiles/unittest && pwd`; \
	    (cd $subdir && \
	      make  \
	        distdir) \
	      || exit 1; \
	  fi; \
	done
make[4]: Entering directory `/disk/itaps-buildslave/moab-distcheck/build/MeshFiles/unittest/io'
make[4]: *** No rule to make target `singlecyl.ccmg', needed by `distdir'.  Stop.
sincerely,
 -The Fathomatic
