[MOAB-dev] r4380 - MOAB/trunk/MeshFiles/unittest/io
    tautges at mcs.anl.gov
    Thu Dec 16 15:39:16 CST 2010
Author: tautges
Date: 2010-12-16 15:39:16 -0600 (Thu, 16 Dec 2010)
New Revision: 4380
Added:
   MOAB/trunk/MeshFiles/unittest/io/dum.sat
Log:
Forgot to add this day before yesterday, tests should run now.
Added: MOAB/trunk/MeshFiles/unittest/io/dum.sat
--- MOAB/trunk/MeshFiles/unittest/io/dum.sat	                        (rev 0)
+++ MOAB/trunk/MeshFiles/unittest/io/dum.sat	2010-12-16 21:39:16 UTC (rev 4380)
@@ -0,0 +1,1256 @@
+1600 0 5 0
+10 Cubit 12.2 17 ACIS 19.0.2 Linux 24 Fri Dec  3 11:35:08 2010
+1 9.9999999999999995e-07 1e-10
+body $5 -1 -1 $-1 $6 $-1 $7 T -5 -5 -5 5 5 5 #
+body $8 -1 -1 $-1 $9 $-1 $10 T 15 -5 -5 25 5 5 #
+body $11 -1 -1 $-1 $12 $-1 $13 T -15 -5 -5 -5 5 5 #
+body $14 -1 -1 $-1 $15 $-1 $16 T -50 -50 -50 50 50 50 #
+body $17 -1 -1 $-1 $18 $-1 $19 T -55 -55 -55 55 55 55 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $20 $-1 $0 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+lump $21 -1 -1 $-1 $-1 $22 $0 T -5 -5 -5 5 5 5 #
+transform $-1 -1 1 0 0 0 1 0 0 0 1 0 0 0 1 no_rotate no_reflect no_shear #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $23 $-1 $1 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+lump $24 -1 -1 $-1 $-1 $25 $1 T 15 -5 -5 25 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $26 $-1 $2 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+lump $27 -1 -1 $-1 $-1 $28 $2 T -15 -5 -5 -5 5 5 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $29 $-1 $3 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+lump $30 -1 -1 $-1 $-1 $31 $3 T -50 -50 -50 50 50 50 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $32 $-1 $4 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 5 #
+lump $33 -1 -1 $-1 $-1 $34 $4 T -55 -55 -55 55 55 55 #
+simple-snl-attrib $-1 -1 $-1 $5 $0 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $35 $-1 $6 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 1 #
+shell $-1 -1 -1 $-1 $-1 $-1 $36 $-1 $6 T -5 -5 -5 5 5 5 #
+simple-snl-attrib $-1 -1 $-1 $8 $1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $37 $-1 $9 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 2 #
+shell $-1 -1 -1 $-1 $-1 $-1 $38 $-1 $9 T 15 -5 -5 25 5 5 #
+simple-snl-attrib $-1 -1 $-1 $11 $2 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 3 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $39 $-1 $12 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 3 #
+shell $-1 -1 -1 $-1 $-1 $-1 $40 $-1 $12 T -15 -5 -5 -5 5 5 #
+simple-snl-attrib $-1 -1 $-1 $14 $3 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 4 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $41 $-1 $15 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 4 #
+shell $-1 -1 -1 $-1 $42 $-1 $43 $-1 $15 T -50 -50 -50 50 50 50 #
+simple-snl-attrib $-1 -1 $-1 $17 $4 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 5 -2147483648 -1 #
+integer_attrib-name_attrib-gen-attrib $-1 -1 $44 $-1 $18 2 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 1 1 @8 CUBIT_ID 5 #
+shell $-1 -1 -1 $-1 $45 $-1 $46 $-1 $18 T -55 -55 -55 55 55 55 #
+simple-snl-attrib $-1 -1 $47 $21 $6 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 1 -2147483648 -1 #
+face $48 -1 -1 $-1 $49 $50 $22 $-1 $51 forward single T -5 -5 5 5 5 5 T -5 5 -5 5 #
+simple-snl-attrib $-1 -1 $52 $24 $9 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 2 -2147483648 -1 #
+face $53 -1 -1 $-1 $54 $55 $25 $-1 $56 forward single T 15 -5 5 25 5 5 F #
+simple-snl-attrib $-1 -1 $57 $27 $12 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 3 -2147483648 -1 #
+face $58 -1 -1 $-1 $59 $60 $28 $-1 $61 forward single T -15 -5 5 -5 5 5 F #
+simple-snl-attrib $-1 -1 $62 $30 $15 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 1 1 1 @17 NEW_SIMPLE_ATTRIB 1 @9 ENTITY_ID 0 3 4 -2147483648 -1 #
+shell $-1 -1 -1 $-1 $63 $-1 $64 $-1 $15 T 15 -5 -5 25 5 5 #
