[MOAB-dev] Sparse vs. dense tags
    Tim Tautges
    tautges at mcs.anl.gov
    Wed Dec 15 15:23:17 CST 2010
It should be sparse.  The crucial difference is that when a dense tag is given a value, all the entities in the same
sequence as the one whose tag is being set are also allocated storage for that tag.  In the case of many sets, this
would waste some storage.  It's a bigger problem when tagging entities, though.
- tim
On 12/15/2010 03:09 PM, Steve Jackson wrote:
> The "GEOM_SENSE_2" tag, used to record the volumes on either side of a surface, is not consistently created as either sparse or dense.  When created from DagMC and its utility tools, the tag is created as dense, but when created from GeomTopoTool (via ReadCGM), the tag is sparse.
> Questions:
> * How big a problem is this inconsistency?  It doesn't seem to cause any errors or disruption.
> * Should the tag be dense or sparse?  The tag is only used on entity sets that represent surfaces, so my guess is that it ought to be sparse, but I don't understand the implementation difference deeply enough to be sure.
> ~S
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
