[MOAB-dev] r4354 - MOAB/trunk/tools
kraftche at cae.wisc.edu
Mon Dec 13 10:42:53 CST 2010
Author: kraftche
Date: 2010-12-13 10:42:52 -0600 (Mon, 13 Dec 2010)
New Revision: 4354
Added:
MOAB/trunk/tools/test_prog_opt.cpp
Modified:
MOAB/trunk/tools/Makefile.am
MOAB/trunk/tools/program_opt.cpp
MOAB/trunk/tools/program_opt.hpp
Log:
Misc enhancements to ProgOptions
o Add new option type std::vector<int> that accepts a comma-separated
list of integer values or integer ranges. For example: 1,2,5-11,3
o Allow tar-like concatenation of short options. For example, this:
-f -g -1.0 -t ACIS -1 -2
can be specified as:
-fgt12 -1.0 ACIS
o If '--' occurs in the argument list then all subsequent arguments
are treated as value arguments rather than flags. So negative
numbers, file names beginning with a '-', etc. can be specified.
o Allow integer values to be specified as hexadecimal or octal using
standard C notation ('0' prefix for octal, '0x' prefix for hex)
o If a flag is specified with both a 'cancel' option and a value
pointer, set value to false when cancel option is encountered.
o Add new flag 'rank_subst'. Flag has no effect when compiled in
serial or if option is not std::string type. If compiled in
parallel, any occurrence of '%' in string option/arg will be
replaced with the rank of the current process in MPI_COMM_WORLD.
o Accept flags for required args (for now the only flag that makes
sense is rank_subst)
o Allow optional arguments at a single location in the ordered list
of arguments. See addOptionalArgs and getArgs.
o Add unit tests
This almost gets us to the point of being able to use ProgOptions to
parse the command line for mbconvert. I think the only thing we're
still missing is some enhancements to the 'add_cancel_option' function
-ality. Mainly the ability to cancel (clear) string options and the
ability to specify a short version of cancel options (-a vs. -A in
mbconvert.)
Modified: MOAB/trunk/tools/Makefile.am
--- MOAB/trunk/tools/Makefile.am 2010-12-11 15:13:43 UTC (rev 4353)
+++ MOAB/trunk/tools/Makefile.am 2010-12-13 16:42:52 UTC (rev 4354)
@@ -137,3 +137,13 @@
mbtagprop_SOURCES = parse.cpp parse.hpp propagate_tags.cpp
mbmem_SOURCES = mbmem.cpp
parread_SOURCES = parread.cpp
+check_PROGRAMS = test_prog_opt
+TESTS = $(check_PROGRAMS)
+test_prog_opt_SOURCES = test_prog_opt.cpp
+test_prog_opt_CPPFLAGS = -I$(top_srcdir)/test $(AM_CPPFLAGS) $(CPPFLAGS)
+test_prog_opt_LDADD = libprogram_opt.la
Modified: MOAB/trunk/tools/program_opt.cpp
--- MOAB/trunk/tools/program_opt.cpp 2010-12-11 15:13:43 UTC (rev 4353)
+++ MOAB/trunk/tools/program_opt.cpp 2010-12-13 16:42:52 UTC (rev 4354)
@@ -2,14 +2,25 @@
#include <sstream>
#include <iomanip>
#include <cstdlib>
+#include <list>
+#include <limits>
+#include <assert.h>
+#include <string.h>
#include "program_opt.hpp"
+#ifdef USE_MPI
+# include "moab_mpi.h"
+#endif
class ProgOpt{
enum types{
FLAG = 0,
- INT, REAL, STRING
+ INT,
+ REAL,
+ STRING,
+ INT_VECT
template <typename T>
@@ -27,6 +38,8 @@
