[MOAB-dev] r4353 - MOAB/trunk/src
bmsmith6 at wisc.edu
Sat Dec 11 09:13:43 CST 2010
Author: bmsmith
Date: 2010-12-11 09:13:43 -0600 (Sat, 11 Dec 2010)
New Revision: 4353
Modified:
MOAB/trunk/src/GeomUtil.cpp
Log:
Fix minor bugs and compiler warning.
Modified: MOAB/trunk/src/GeomUtil.cpp
--- MOAB/trunk/src/GeomUtil.cpp 2010-12-10 18:51:46 UTC (rev 4352)
+++ MOAB/trunk/src/GeomUtil.cpp 2010-12-11 15:13:43 UTC (rev 4353)
@@ -239,10 +239,13 @@
pip2*inverse_sum*vertices[1]);
// To minimize numerical error, get index of largest magnitude direction.
- int idx;
+ int idx = 0;
double max_abs_dir = 0;
for(unsigned int i=0; i<3; ++i) {
- if( fabs(direction[i]) > max_abs_dir ) idx = i;
+ if( fabs(direction[i]) > max_abs_dir ) {
+ idx = i;
+ max_abs_dir = fabs(direction[i]);
const double dist = (intersection[idx]-origin[idx])/direction[idx];
@@ -251,7 +254,7 @@
if(type) *type = NONE;
return false;
- if(neg_ray_len && *neg_ray_len>dist) {
+ if(neg_ray_len && *neg_ray_len>=dist) {
return false;
