[MOAB-dev] r4333 - in MOAB/trunk/src: . moab
bmsmith6 at wisc.edu
Tue Dec 7 11:21:27 CST 2010
Author: bmsmith
Date: 2010-12-07 11:21:27 -0600 (Tue, 07 Dec 2010)
New Revision: 4333
Modified:
MOAB/trunk/src/OrientedBoxTreeTool.cpp
MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp
Log:
Changes to ray_intersect_sets:
-Add ability to search behind the origin for intersections. This is useful
for particle tracking through overlaps.
-Add ability to avoid returning facets, specified in a vector. This is
useful for avoiding facets that have previously been intersected.
-Use the plucker_ray_tri_intersect test to prevent particles from leaking
between topologically adjacent facets. It consistently identifies edge
and node intersections.
-If an edge/node intersection is found, check to make sure that it
actually pierces the boundary of the volume.
-Add a new mode to add_intersections that is optimized for DagMC. It
returns 1 intersection in the forward direction with correct orientation.
If it exists, it will return 1 intersection in the reverse direction with
correct orientation and within a distance limit.
-These options are triggered by passing pointers. The existing behavior
should be unchanged.
Modified: MOAB/trunk/src/OrientedBoxTreeTool.cpp
--- MOAB/trunk/src/OrientedBoxTreeTool.cpp 2010-12-07 16:44:44 UTC (rev 4332)
+++ MOAB/trunk/src/OrientedBoxTreeTool.cpp 2010-12-07 17:21:27 UTC (rev 4333)
@@ -25,6 +25,7 @@
#include "moab/Range.hpp"
#include "moab/CN.hpp"
#include "moab/GeomUtil.hpp"
+#include "moab/GeomTopoTool.hpp"
#include "MBTagConventions.hpp"
#include <iostream>
#include <iomanip>
@@ -38,6 +39,137 @@
namespace moab {
+/**\brief Determine if a ray-edge/node intersection is glancing or piercing.
+ * This function avoids asking for upward adjacencies to prevent their
+ * creation.
+ *\param tri The intersected triangle
+ *\param ray_direction The direction of the ray
+ *\param int_type The type of intersection (EDGE0, EDGE1, NODE2, ...)
+ *\param close_tris Vector of triangles in the neighborhood of the intersection
+ *\param close_senses Vector of surface senses for tris in the neighborhood of
+ * the intersection
+ *\return True if piercing, false otherwise.
+bool edge_node_intersect(const EntityHandle tri,
+ const CartVect& ray_direction,
+ const GeomUtil::intersection_type int_type,
+ const std::vector<EntityHandle>& close_tris,
+ const std::vector<int>& close_senses,
+ const Interface* MBI ) {
+ // get the node of the triangle
+ const EntityHandle* conn;
+ int len;
+ ErrorCode rval = MBI->get_connectivity( tri, conn, len );
+ if(MB_SUCCESS!=rval || 3!=len) return MB_FAILURE;
+ // get adjacent tris (and keep their corresponding senses)
+ std::vector<EntityHandle> adj_tris;
+ std::vector<int> adj_senses;
+ // node intersection
+ if(GeomUtil::NODE0==int_type || GeomUtil::NODE1==int_type || GeomUtil::NODE2==int_type) {
+ // get the intersected node
+ EntityHandle node;
+ if (GeomUtil::NODE0==int_type) node = conn[0];
+ else if(GeomUtil::NODE1==int_type) node = conn[1];
