[MOAB-dev] r4332 - in MOAB/trunk: src test
bmsmith6 at wisc.edu
Tue Dec 7 10:44:45 CST 2010
Author: bmsmith
Date: 2010-12-07 10:44:44 -0600 (Tue, 07 Dec 2010)
New Revision: 4332
Modified:
MOAB/trunk/src/OrientedBox.cpp
MOAB/trunk/src/OrientedBox.hpp
MOAB/trunk/test/OBBTest.cpp
Log:
-Add ability to search in reverse direction to box.intersect_ray. This
is useful for particle tracking through overlaps and numerical precision
problems.
-Check distance limits (in both directions) against sides of the box.
Makes tree pruning due to distance limits more efficient.
-Existing use of the function should not change.
-Added a few unit tests for using a distance limit in the reverse
direction.
Modified: MOAB/trunk/src/OrientedBox.cpp
--- MOAB/trunk/src/OrientedBox.cpp 2010-12-06 21:45:43 UTC (rev 4331)
+++ MOAB/trunk/src/OrientedBox.cpp 2010-12-07 16:44:44 UTC (rev 4332)
@@ -467,38 +467,123 @@
+/* This is a helper function to check limits on ray length, turning the box-ray
+ * intersection test into a box-segment intersection test. Use this to test the
+ * limits against one side (plane) of the box. The side of the box (plane) is
+ * normal to an axis.
+ * normal_par_pos Coordinate of particle's position along axis normal to side of box
+ * normal_par_dir Coordinate of particle's direction along axis normal to side of box
+ * half_extent Distance between center of box and side of box
+ * nonneg_ray_len Maximum ray length in positive direction (in front of origin)
+ * neg_ray_len Maximum ray length in negative direction (behind origin)
+ * return true if intersection with plane occurs within distance limits
+ * ray equation: intersection = origin + dist*direction
+ * plane equation: intersection.plane_normal = half_extent
+ * Assume plane_normal and direction are unit vectors. Combine equations.
+ * (origin + dist*direction).plane_normal = half_extent
+ * origin.plane_normal + dist*direction.plane_normal = half_extent
+ * dist = (half_extent - origin.plane_normal)/(direction.plane_normal)
+ * Although this solves for distance, avoid floating point division.
+ * dist*direction.plane_normal = half_extent - origin.plane_normal
+ * Use inequalities to test dist against ray length limits. Be aware that
+ * inequalities change due to sign of direction.plane_normal.
+inline bool check_ray_limits(const double normal_par_pos,
+ const double normal_par_dir,
+ const double half_extent,
+ const double* nonneg_ray_len,
+ const double* neg_ray_len ) {
+ const double extent_pos_diff = half_extent - normal_par_pos;
+ // limit in positive direction
+ if(nonneg_ray_len) { // should be 0 <= t <= nonneg_ray_len
+ assert(0 <= *nonneg_ray_len);
+ if (normal_par_dir>0) { // if/else if needed for pos/neg divisor
+ if(*nonneg_ray_len*normal_par_dir>=extent_pos_diff && extent_pos_diff>=0) return true;
+ } else if(normal_par_dir<0) {
+ if(*nonneg_ray_len*normal_par_dir<=extent_pos_diff && extent_pos_diff<=0) return true;
