[MOAB-dev] r4328 - in MOAB/trunk: . MeshFiles/unittest	MeshFiles/unittest/io config doc examples examples/simple	itaps itaps/igeom itaps/imesh src src/io src/io/mhdf	src/io/mhdf/doc src/io/mhdf/example src/io/mhdf/include	src/io/mhdf/src src/io/moab src/moab src/oldinc src/parallel	src/parallel/moab test test/h5file test/io test/parallel	tools tools/mbcoupler tools/refiner
    kraftche at cae.wisc.edu
    Fri Dec  3 17:05:14 CST 2010
Author: kraftche
Date: 2010-12-03 17:05:14 -0600 (Fri, 03 Dec 2010)
New Revision: 4328
Modified:
   MOAB/trunk/
   MOAB/trunk/MeshFiles/unittest/64bricks_512hex.h5m
   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.1.cub
   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.2.cub
   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.cub
   MOAB/trunk/MeshFiles/unittest/io/gmsh2.msh
   MOAB/trunk/MeshFiles/unittest/io/ho_test.cub
   MOAB/trunk/MeshFiles/unittest/io/ho_test.g
   MOAB/trunk/MeshFiles/unittest/io/sample.stl
   MOAB/trunk/MeshFiles/unittest/io/test.cub
   MOAB/trunk/MeshFiles/unittest/io/test.nas
   MOAB/trunk/MeshFiles/unittest/ptest.cub
   MOAB/trunk/config/AutoconfHeader.cmake
   MOAB/trunk/config/FindCGM.cmake
   MOAB/trunk/config/FindHDF5.cmake
   MOAB/trunk/config/FindNetCDF.cmake
   MOAB/trunk/config/Findgraphviz.cmake
   MOAB/trunk/config/Findverdict.cmake
   MOAB/trunk/config/GetAcInitVersion.cmake
   MOAB/trunk/config/ITAPSFortranMangling.cmake
   MOAB/trunk/config/TemplateSpecialization.cxx
   MOAB/trunk/config/TestingConfig.h.in
   MOAB/trunk/config/acis.m4
   MOAB/trunk/config/boost.m4
   MOAB/trunk/config/ccmio.m4
   MOAB/trunk/config/cplusplus.m4
   MOAB/trunk/config/hdf5.m4
   MOAB/trunk/config/macro_val.m4
   MOAB/trunk/config/makevar.m4
   MOAB/trunk/config/mpi.m4
   MOAB/trunk/config/netcdf.m4
   MOAB/trunk/doc/user.dox.in
   MOAB/trunk/examples/A.1.ele
   MOAB/trunk/examples/A.1.node
   MOAB/trunk/examples/FileRead.cpp
   MOAB/trunk/examples/GeomSetHierarchy.cpp
   MOAB/trunk/examples/README.FileReader
   MOAB/trunk/examples/SetsNTags.cpp
   MOAB/trunk/examples/SkinMesh.cpp
   MOAB/trunk/examples/SurfArea.cpp
   MOAB/trunk/examples/simple/GetEntities.cpp
   MOAB/trunk/examples/simple/makefile.in
   MOAB/trunk/itaps/Makefile.am
   MOAB/trunk/itaps/iBase.h
   MOAB/trunk/itaps/iBase_f.h
   MOAB/trunk/itaps/igeom/Makefile.am
   MOAB/trunk/itaps/igeom/brick.stp
   MOAB/trunk/itaps/igeom/iGeom-Defs.inc.in
   MOAB/trunk/itaps/igeom/iGeom.h
   MOAB/trunk/itaps/igeom/iGeom_MOAB.cpp
   MOAB/trunk/itaps/igeom/iGeom_MOAB.hpp
   MOAB/trunk/itaps/igeom/iGeom_f.h
   MOAB/trunk/itaps/igeom/testgeom.cc
   MOAB/trunk/itaps/imesh/CMakeLists.txt
   MOAB/trunk/itaps/imesh/MOAB_iMeshP_unit_tests.cpp
   MOAB/trunk/itaps/imesh/Makefile.am
   MOAB/trunk/itaps/imesh/brick.vtk
   MOAB/trunk/itaps/imesh/iMesh-Defs.inc.in
   MOAB/trunk/itaps/imesh/iMesh.dox
   MOAB/trunk/itaps/imesh/iMesh.h
   MOAB/trunk/itaps/imesh/iMeshP.h
   MOAB/trunk/itaps/imesh/iMeshP_MOAB.cpp
   MOAB/trunk/itaps/imesh/iMeshP_f.h
   MOAB/trunk/itaps/imesh/iMesh_extensions.h
   MOAB/trunk/itaps/imesh/iMesh_f.h
   MOAB/trunk/itaps/imesh/partest.cpp
   MOAB/trunk/itaps/imesh/quad9.cub
   MOAB/trunk/itaps/imesh/testc_cbind.c
   MOAB/trunk/itaps/mkprotos.sh
   MOAB/trunk/src/AEntityFactory.cpp
   MOAB/trunk/src/AEntityFactory.hpp
   MOAB/trunk/src/AdaptiveKDTree.cpp
   MOAB/trunk/src/AffineXform.cpp
   MOAB/trunk/src/AffineXform.hpp
   MOAB/trunk/src/AxisBox.cpp
   MOAB/trunk/src/AxisBox.hpp
   MOAB/trunk/src/BSPTree.cpp
   MOAB/trunk/src/BSPTreePoly.cpp
   MOAB/trunk/src/BitTagServer.cpp
   MOAB/trunk/src/BitTagServer.hpp
   MOAB/trunk/src/CMakeLists.txt
   MOAB/trunk/src/CN.cpp
   MOAB/trunk/src/CartVect.cpp
   MOAB/trunk/src/Core.cpp
   MOAB/trunk/src/DualTool.cpp
   MOAB/trunk/src/ElementSequence.hpp
   MOAB/trunk/src/EntitySequence.cpp
   MOAB/trunk/src/EntitySequence.hpp
   MOAB/trunk/src/Error.hpp
   MOAB/trunk/src/FCDefs.h.in
   MOAB/trunk/src/Factory.cpp
   MOAB/trunk/src/FileOptions.cpp
   MOAB/trunk/src/FileOptions.hpp
   MOAB/trunk/src/GeomTopoTool.cpp
   MOAB/trunk/src/GeomUtil.cpp
   MOAB/trunk/src/HigherOrderFactory.cpp
   MOAB/trunk/src/HomXform.cpp
   MOAB/trunk/src/Internals.hpp
   MOAB/trunk/src/MBCN.h
   MOAB/trunk/src/MBCNArrays.hpp
   MOAB/trunk/src/MBEntityType.h
   MOAB/trunk/src/MBTagConventions.hpp
   MOAB/trunk/src/Makefile.am
   MOAB/trunk/src/Matrix3.cpp
   MOAB/trunk/src/Matrix3.hpp
   MOAB/trunk/src/MeshSet.cpp
   MOAB/trunk/src/MeshSet.hpp
   MOAB/trunk/src/MeshSetSequence.cpp
   MOAB/trunk/src/MeshSetSequence.hpp
   MOAB/trunk/src/MeshTopoUtil.cpp
   MOAB/trunk/src/OrientedBox.cpp
   MOAB/trunk/src/OrientedBox.hpp
   MOAB/trunk/src/OrientedBoxTreeTool.cpp
   MOAB/trunk/src/PolyElementSeq.cpp
   MOAB/trunk/src/PolyElementSeq.hpp
   MOAB/trunk/src/Range.cpp
   MOAB/trunk/src/RangeSeqIntersectIter.cpp
   MOAB/trunk/src/RangeSeqIntersectIter.hpp
   MOAB/trunk/src/ReadUtil.cpp
   MOAB/trunk/src/ReadUtil.hpp
   MOAB/trunk/src/ReaderWriterSet.cpp
   MOAB/trunk/src/ScdElementData.cpp
   MOAB/trunk/src/ScdElementData.hpp
   MOAB/trunk/src/ScdVertexData.cpp
   MOAB/trunk/src/ScdVertexData.hpp
   MOAB/trunk/src/SequenceData.cpp
   MOAB/trunk/src/SequenceData.hpp
   MOAB/trunk/src/SequenceManager.cpp
   MOAB/trunk/src/SequenceManager.hpp
   MOAB/trunk/src/Skinner.cpp
   MOAB/trunk/src/SparseTagCollection.cpp
   MOAB/trunk/src/SparseTagCollection.hpp
   MOAB/trunk/src/SparseTagSuperCollection.cpp
   MOAB/trunk/src/SparseTagSuperCollection.hpp
   MOAB/trunk/src/StructuredElementSeq.cpp
   MOAB/trunk/src/StructuredElementSeq.hpp
   MOAB/trunk/src/SweptElementData.cpp
   MOAB/trunk/src/SweptElementData.hpp
   MOAB/trunk/src/SweptElementSeq.cpp
   MOAB/trunk/src/SweptElementSeq.hpp
   MOAB/trunk/src/SweptVertexData.cpp
   MOAB/trunk/src/SweptVertexData.hpp
   MOAB/trunk/src/SysUtil.cpp
   MOAB/trunk/src/SysUtil.hpp
   MOAB/trunk/src/TagCompare.hpp
   MOAB/trunk/src/TagInfo.cpp
   MOAB/trunk/src/TagInfo.hpp
   MOAB/trunk/src/TagServer.cpp
   MOAB/trunk/src/TagServer.hpp
   MOAB/trunk/src/TypeSequenceManager.cpp
   MOAB/trunk/src/TypeSequenceManager.hpp
   MOAB/trunk/src/UnstructuredElemSeq.cpp
   MOAB/trunk/src/UnstructuredElemSeq.hpp
   MOAB/trunk/src/Util.cpp
   MOAB/trunk/src/VarLenTag.hpp
   MOAB/trunk/src/VertexSequence.cpp
   MOAB/trunk/src/VertexSequence.hpp
   MOAB/trunk/src/WriteUtil.cpp
   MOAB/trunk/src/WriteUtil.hpp
   MOAB/trunk/src/io/CMakeLists.txt
   MOAB/trunk/src/io/ExoIIUtil.cpp
   MOAB/trunk/src/io/ExoIIUtil.hpp
   MOAB/trunk/src/io/FileTokenizer.cpp
   MOAB/trunk/src/io/FileTokenizer.hpp
   MOAB/trunk/src/io/GmshUtil.cpp
   MOAB/trunk/src/io/GmshUtil.hpp
   MOAB/trunk/src/io/Makefile.am
   MOAB/trunk/src/io/ReadABAQUS.cpp
   MOAB/trunk/src/io/ReadABAQUS.hpp
   MOAB/trunk/src/io/ReadCCMIO.cpp
   MOAB/trunk/src/io/ReadCCMIO.hpp
   MOAB/trunk/src/io/ReadCGM.cpp
   MOAB/trunk/src/io/ReadCGM.hpp
   MOAB/trunk/src/io/ReadGmsh.cpp
   MOAB/trunk/src/io/ReadGmsh.hpp
   MOAB/trunk/src/io/ReadHDF5.cpp
   MOAB/trunk/src/io/ReadHDF5.hpp
   MOAB/trunk/src/io/ReadIDEAS.cpp
   MOAB/trunk/src/io/ReadIDEAS.hpp
   MOAB/trunk/src/io/ReadMCNP5.cpp
   MOAB/trunk/src/io/ReadMCNP5.hpp
   MOAB/trunk/src/io/ReadNASTRAN.cpp
   MOAB/trunk/src/io/ReadNASTRAN.hpp
   MOAB/trunk/src/io/ReadNCDF.cpp
   MOAB/trunk/src/io/ReadNCDF.hpp
   MOAB/trunk/src/io/ReadSTL.cpp
   MOAB/trunk/src/io/ReadSTL.hpp
   MOAB/trunk/src/io/ReadSmf.cpp
   MOAB/trunk/src/io/ReadSmf.hpp
   MOAB/trunk/src/io/ReadSms.cpp
   MOAB/trunk/src/io/ReadSms.hpp
   MOAB/trunk/src/io/ReadTetGen.cpp
   MOAB/trunk/src/io/ReadTetGen.hpp
   MOAB/trunk/src/io/ReadVtk.cpp
   MOAB/trunk/src/io/ReadVtk.hpp
   MOAB/trunk/src/io/SMF_State.cpp
   MOAB/trunk/src/io/SMF_State.hpp
   MOAB/trunk/src/io/Tqdcfr.cpp
   MOAB/trunk/src/io/Tqdcfr.hpp
   MOAB/trunk/src/io/VtkUtil.cpp
   MOAB/trunk/src/io/VtkUtil.hpp
   MOAB/trunk/src/io/WriteAns.cpp
   MOAB/trunk/src/io/WriteAns.hpp
   MOAB/trunk/src/io/WriteCCMIO.cpp
   MOAB/trunk/src/io/WriteCCMIO.hpp
   MOAB/trunk/src/io/WriteGMV.cpp
   MOAB/trunk/src/io/WriteGMV.hpp
   MOAB/trunk/src/io/WriteGmsh.cpp
   MOAB/trunk/src/io/WriteGmsh.hpp
   MOAB/trunk/src/io/WriteHDF5.cpp
   MOAB/trunk/src/io/WriteHDF5.hpp
   MOAB/trunk/src/io/WriteNCDF.cpp
   MOAB/trunk/src/io/WriteNCDF.hpp
   MOAB/trunk/src/io/WriteSLAC.cpp
   MOAB/trunk/src/io/WriteSLAC.hpp
   MOAB/trunk/src/io/WriteSTL.cpp
   MOAB/trunk/src/io/WriteSTL.hpp
   MOAB/trunk/src/io/WriteSmf.cpp
   MOAB/trunk/src/io/WriteSmf.hpp
   MOAB/trunk/src/io/WriteTemplate.cpp
   MOAB/trunk/src/io/WriteTemplate.hpp
   MOAB/trunk/src/io/WriteVtk.cpp
   MOAB/trunk/src/io/WriteVtk.hpp
   MOAB/trunk/src/io/exodus_order.h
   MOAB/trunk/src/io/mhdf/CMakeLists.txt
   MOAB/trunk/src/io/mhdf/Makefile.am
   MOAB/trunk/src/io/mhdf/doc/Doxyfile
   MOAB/trunk/src/io/mhdf/example/hexes_to_gmsh.c
   MOAB/trunk/src/io/mhdf/example/info.c
   MOAB/trunk/src/io/mhdf/include/mhdf.h
   MOAB/trunk/src/io/mhdf/src/adjacency.c
   MOAB/trunk/src/io/mhdf/src/connectivity.c
   MOAB/trunk/src/io/mhdf/src/file-desc.c
   MOAB/trunk/src/io/mhdf/src/file-handle.c
   MOAB/trunk/src/io/mhdf/src/file-handle.h
   MOAB/trunk/src/io/mhdf/src/file.c
   MOAB/trunk/src/io/mhdf/src/names-and-paths.h
   MOAB/trunk/src/io/mhdf/src/nodes.c
   MOAB/trunk/src/io/mhdf/src/sets.c
   MOAB/trunk/src/io/mhdf/src/status.c
   MOAB/trunk/src/io/mhdf/src/status.h
   MOAB/trunk/src/io/mhdf/src/tags.c
   MOAB/trunk/src/io/mhdf/src/util.c
   MOAB/trunk/src/io/mhdf/src/util.h
   MOAB/trunk/src/io/moab/ExoIIInterface.hpp
   MOAB/trunk/src/io/patran_order.h
   MOAB/trunk/src/moab/AdaptiveKDTree.hpp
   MOAB/trunk/src/moab/BSPTree.hpp
   MOAB/trunk/src/moab/BSPTreePoly.hpp
   MOAB/trunk/src/moab/CN.hpp
   MOAB/trunk/src/moab/CartVect.hpp
   MOAB/trunk/src/moab/Core.hpp
   MOAB/trunk/src/moab/DualTool.hpp
   MOAB/trunk/src/moab/EntityHandle.hpp.in
   MOAB/trunk/src/moab/Forward.hpp
   MOAB/trunk/src/moab/GeomTopoTool.hpp
   MOAB/trunk/src/moab/GeomUtil.hpp
   MOAB/trunk/src/moab/HigherOrderFactory.hpp
   MOAB/trunk/src/moab/HomXform.hpp
   MOAB/trunk/src/moab/Interface.hpp
   MOAB/trunk/src/moab/MeshTopoUtil.hpp
   MOAB/trunk/src/moab/OrientedBoxTreeTool.hpp
   MOAB/trunk/src/moab/Range.hpp
   MOAB/trunk/src/moab/RangeMap.hpp
   MOAB/trunk/src/moab/ReadUtilIface.hpp
   MOAB/trunk/src/moab/ReaderIface.hpp
   MOAB/trunk/src/moab/ReaderWriterSet.hpp
   MOAB/trunk/src/moab/Skinner.hpp
   MOAB/trunk/src/moab/Types.hpp
   MOAB/trunk/src/moab/UnknownInterface.hpp
   MOAB/trunk/src/moab/Util.hpp
   MOAB/trunk/src/moab/Version.h.in
   MOAB/trunk/src/moab/WriteUtilIface.hpp
   MOAB/trunk/src/moab/WriterIface.hpp
   MOAB/trunk/src/oldinc/MBParallelComm.hpp
   MOAB/trunk/src/oldinc/MBParallelData.hpp
   MOAB/trunk/src/oldinc/MBProcConfig.hpp
   MOAB/trunk/src/oldinc/MBmpi.h
   MOAB/trunk/src/parallel/CMakeLists.txt
   MOAB/trunk/src/parallel/MBParallelConventions.h
   MOAB/trunk/src/parallel/Makefile.am
   MOAB/trunk/src/parallel/ParallelData.cpp
   MOAB/trunk/src/parallel/ProcConfig.cpp
   MOAB/trunk/src/parallel/ReadParallel.cpp
   MOAB/trunk/src/parallel/ReadParallel.hpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
   MOAB/trunk/src/parallel/WriteHDF5Parallel.hpp
   MOAB/trunk/src/parallel/crystal.c
   MOAB/trunk/src/parallel/crystal.h
   MOAB/trunk/src/parallel/errmem.c
   MOAB/trunk/src/parallel/errmem.h
   MOAB/trunk/src/parallel/fcrystal.c
   MOAB/trunk/src/parallel/gs.c
   MOAB/trunk/src/parallel/gs.h
   MOAB/trunk/src/parallel/minmax.h
   MOAB/trunk/src/parallel/moab/ParallelComm.hpp
   MOAB/trunk/src/parallel/moab/ParallelData.hpp
   MOAB/trunk/src/parallel/moab/ProcConfig.hpp
   MOAB/trunk/src/parallel/moab_mpi.h
   MOAB/trunk/src/parallel/moab_mpi_config.h.in
   MOAB/trunk/src/parallel/sort.c
   MOAB/trunk/src/parallel/sort.h
   MOAB/trunk/src/parallel/sort_imp.c
   MOAB/trunk/src/parallel/transfer.c
   MOAB/trunk/src/parallel/transfer.h
   MOAB/trunk/src/parallel/tuple_list.c
   MOAB/trunk/src/parallel/tuple_list.h
   MOAB/trunk/src/parallel/types.h
   MOAB/trunk/test/GeomUtilTests.cpp
   MOAB/trunk/test/MBTest.cpp
   MOAB/trunk/test/OBBTest.cpp
   MOAB/trunk/test/TagTest.cpp
   MOAB/trunk/test/TestTypeSequenceManager.cpp
   MOAB/trunk/test/TestUtil.hpp
   MOAB/trunk/test/Test_MBMeshSet.cpp
   MOAB/trunk/test/VarLenTagTest.cpp
   MOAB/trunk/test/adaptive_kd_tree_tests.cpp
   MOAB/trunk/test/bsp_tree_poly_test.cpp
   MOAB/trunk/test/bsp_tree_test.cpp
   MOAB/trunk/test/h5file/v3_dodec.h5m
   MOAB/trunk/test/internals_test.cpp
   MOAB/trunk/test/io/Makefile.am
   MOAB/trunk/test/io/VtkTest.cpp
   MOAB/trunk/test/io/cub_file_test.cc
   MOAB/trunk/test/io/exodus_test.cc
   MOAB/trunk/test/io/gmsh_test.cc
   MOAB/trunk/test/io/nastran_test.cc
   MOAB/trunk/test/io/stl_test.cc
   MOAB/trunk/test/io/test_exo.cpp
   MOAB/trunk/test/io/test_rms.cpp
   MOAB/trunk/test/kd_tree_test.cpp
   MOAB/trunk/test/kd_tree_time.cpp
   MOAB/trunk/test/kd_tree_tool.cpp
   MOAB/trunk/test/mbcn_test.cc
   MOAB/trunk/test/merge_test.cpp
   MOAB/trunk/test/parallel/mbparallelcomm_test.cpp
   MOAB/trunk/test/parallel/parallel_hdf5_test.cc
   MOAB/trunk/test/parallel/parallel_unit_tests.cpp
   MOAB/trunk/test/parallel/parallel_write_test.cc
   MOAB/trunk/test/parallel/pcomm_serial.cpp
   MOAB/trunk/test/parallel/pcomm_unit.cpp
   MOAB/trunk/test/parallel/scdtest.cpp
   MOAB/trunk/test/parallel/uber_parallel_test.cpp
   MOAB/trunk/test/scdseq_test.cpp
   MOAB/trunk/test/scdseq_timing.cpp
   MOAB/trunk/test/test_adj.cpp
   MOAB/trunk/tools/mbcoupler/Coupler.cpp
   MOAB/trunk/tools/mbcoupler/Coupler.hpp
   MOAB/trunk/tools/mbcoupler/ElemUtil.cpp
   MOAB/trunk/tools/mbcoupler/ElemUtil.hpp
   MOAB/trunk/tools/refiner/CMakeLists.txt
   MOAB/trunk/tools/refiner/EdgeSizeEvaluator.cpp
   MOAB/trunk/tools/refiner/EdgeSizeEvaluator.hpp
   MOAB/trunk/tools/refiner/EdgeSizeSimpleImplicit.cpp
   MOAB/trunk/tools/refiner/EdgeSizeSimpleImplicit.hpp
   MOAB/trunk/tools/refiner/EntityRefiner.cpp
   MOAB/trunk/tools/refiner/EntityRefiner.hpp
   MOAB/trunk/tools/refiner/MeshOutputFunctor.cpp
   MOAB/trunk/tools/refiner/MeshOutputFunctor.hpp
   MOAB/trunk/tools/refiner/MeshRefiner.cpp
   MOAB/trunk/tools/refiner/MeshRefiner.hpp
   MOAB/trunk/tools/refiner/ProcessSet.cpp
   MOAB/trunk/tools/refiner/ProcessSet.hpp
   MOAB/trunk/tools/refiner/RefinerTagManager.cpp
   MOAB/trunk/tools/refiner/RefinerTagManager.hpp
   MOAB/trunk/tools/refiner/SimplexTemplateRefiner.cpp
   MOAB/trunk/tools/refiner/SimplexTemplateRefiner.hpp
   MOAB/trunk/tools/refiner/SimplexTemplateTagAssigner.cpp
   MOAB/trunk/tools/refiner/SimplexTemplateTagAssigner.hpp
   MOAB/trunk/tools/refiner/SplitVertices.cpp
   MOAB/trunk/tools/refiner/SplitVertices.hpp
   MOAB/trunk/tools/refiner/fourVolsBare.cub
   MOAB/trunk/tools/refiner/test_mesh_refiner.cpp
   MOAB/trunk/tools/sphere_decomp.cpp
Log:
merge new capability to directly access tag storage
Property changes on: MOAB/trunk
___________________________________________________________________
Added: svn:mergeinfo
   + /MOAB/branches/jk-direct-tag:4069-4327
Property changes on: MOAB/trunk/MeshFiles/unittest/64bricks_512hex.h5m
Deleted: svn:mergeinfo
Property changes on: MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.1.cub
Property changes on: MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.2.cub
Property changes on: MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.cub
Property changes on: MOAB/trunk/MeshFiles/unittest/io/gmsh2.msh
Property changes on: MOAB/trunk/MeshFiles/unittest/io/ho_test.cub
Property changes on: MOAB/trunk/MeshFiles/unittest/io/ho_test.g
Property changes on: MOAB/trunk/MeshFiles/unittest/io/sample.stl
