[MOAB-dev] r4327 - MOAB/branches/Version4.0
    tautges at mcs.anl.gov
    Fri Dec  3 15:39:59 CST 2010
Author: tautges
Date: 2010-12-03 15:39:59 -0600 (Fri, 03 Dec 2010)
New Revision: 4327
Modified:
   MOAB/branches/Version4.0/KNOWN_ISSUES
Log:
Updating KNOWN_ISSUES, this is a straight copy from the trunk.
Modified: MOAB/branches/Version4.0/KNOWN_ISSUES
--- MOAB/branches/Version4.0/KNOWN_ISSUES	2010-12-03 21:39:24 UTC (rev 4326)
+++ MOAB/branches/Version4.0/KNOWN_ISSUES	2010-12-03 21:39:59 UTC (rev 4327)
@@ -3,32 +3,15 @@
     https://trac.mcs.anl.gov/projects/ITAPS/wiki
-#   Severity  Summary/Details
-33  critical  Parallel read failure for > 32procs
+#   Severity      Summary/Details
+#161 enhancement  Need better MBCN test
+#170 enhancement  get_connectivity should optionally return an offset list
+#29  enhancement  Specifying sets not to write
+#32  enhancement  support writing compressed (szip) HDF5 files
+#138 enhancement  Error handlers
+#141 enhancement  reader/writer file set
+#172 enhancement  environmental variables
+#174 enhancement  Mechanism for leaving readers instantiated
+#26  enhancement  pipelining utilities
-35  major     MOAB parallel memory leak
-149 major     Usage notes for iMesh/iGeom on MOAB/CGM implementations
-161 major     Need better MBCN test
-163 major     Assertion failure reading 2 meshes in mbcoupler_test
-22  minor     iMesh_getAdjTable() is incorrect
-29  minor     Specifying sets not to write
-30  minor     geometric vertex sets not partitioned
-32  minor     support writing compressed (szip) HDF5 files
-138 minor     Error handlers
-141 minor     reader/writer file set
-142 minor     Document use of MBReaderWriterSet
-162 minor     Cub file reader fails if file contains named blocks
-26  trivial   pipelining utilities
