[MOAB-dev] r4284 - in MOAB/trunk: . config
kraftche at cae.wisc.edu
Thu Nov 18 16:47:18 CST 2010
Author: kraftche
Date: 2010-11-18 16:47:18 -0600 (Thu, 18 Nov 2010)
New Revision: 4284
Modified:
MOAB/trunk/config/compiler.m4
MOAB/trunk/configure.ac
Log:
strip -lgcc_s, -lm, and -lc from C++ runtime libs list rename ITAPS_LIBTOOL_VAR as FATHOM_LIBTOOL_VAR
Modified: MOAB/trunk/config/compiler.m4
--- MOAB/trunk/config/compiler.m4 2010-11-18 22:46:03 UTC (rev 4283)
+++ MOAB/trunk/config/compiler.m4 2010-11-18 22:47:18 UTC (rev 4284)
@@ -5,7 +5,7 @@
# libtool variable name
# variable in which to store result
-AC_DEFUN([ITAPS_LIBTOOL_VAR], [
+AC_DEFUN([FATHOM_LIBTOOL_VAR], [
echo "SED=$SED" > .tmp
./libtool --tag=$1 --config >>.tmp
echo "echo \$$2" >> .tmp
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2010-11-18 22:46:03 UTC (rev 4283)
+++ MOAB/trunk/configure.ac 2010-11-18 22:47:18 UTC (rev 4284)
@@ -257,11 +257,26 @@
# Extract libtool config
-ITAPS_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [MOAB_CXX_LINKFLAGS])
-ITAPS_LIBTOOL_VAR( [CXX], [postdeps], [MOAB_CXX_LIBS])
+FATHOM_LIBTOOL_VAR( [CXX], [compiler_lib_search_path], [MOAB_CXX_LINKFLAGS])
+FATHOM_LIBTOOL_VAR( [CXX], [postdeps], [MOAB_CXX_LIBS_TMP])
+MOAB_CXX_LIBS=
+for lib in $MOAB_CXX_LIBS_TMP; do
+ case $lib in
+ -lgcc_s)
+ -lm)
+ -lc)
+ MOAB_CXX_LIBS="$MOAB_CXX_LIBS $lib"
+ esac
+done
AC_SUBST(MOAB_CXX_LINKFLAGS)
AC_SUBST(MOAB_CXX_LIBS)
# System Headers
