[MOAB-dev] r4283 - in MOAB/trunk: src src/io tools
kraftche at cae.wisc.edu
Thu Nov 18 16:46:03 CST 2010
Author: kraftche
Date: 2010-11-18 16:46:03 -0600 (Thu, 18 Nov 2010)
New Revision: 4283
Modified:
MOAB/trunk/src/GeomTopoTool.cpp
MOAB/trunk/src/WriteUtil.cpp
MOAB/trunk/src/io/ReadSms.cpp
MOAB/trunk/tools/mbmem.cpp
Log:
fix warnings
Modified: MOAB/trunk/src/GeomTopoTool.cpp
--- MOAB/trunk/src/GeomTopoTool.cpp 2010-11-18 22:45:32 UTC (rev 4282)
+++ MOAB/trunk/src/GeomTopoTool.cpp 2010-11-18 22:46:03 UTC (rev 4283)
@@ -36,9 +36,15 @@
const char GEOM_SENSE_N_ENTS_TAG_NAME[] = "GEOM_SENSE_N_ENTS";
const char GEOM_SENSE_N_SENSES_TAG_NAME[] = "GEOM_SENSE_N_SENSES";
-GeomTopoTool::GeomTopoTool(Interface *impl, bool find_geoments) :
- mdbImpl(impl), sense2Tag(0), senseNEntsTag(0), senseNSensesTag(0), obbTree(
- impl), oneVolRootSet(NULL) , contiguous(true) {
+GeomTopoTool::GeomTopoTool(Interface *impl, bool find_geoments)
+ : mdbImpl(impl),
+ sense2Tag(0),
+ senseNEntsTag(0),
+ senseNSensesTag(0),
+ obbTree(impl),
+ contiguous(true),
+ oneVolRootSet(NULL)
ErrorCode result = mdbImpl->tag_create(GEOM_DIMENSION_TAG_NAME, 4,
MB_TAG_SPARSE, geomTag, NULL);
if (MB_SUCCESS != result && MB_ALREADY_ALLOCATED != result) {
Modified: MOAB/trunk/src/WriteUtil.cpp
--- MOAB/trunk/src/WriteUtil.cpp 2010-11-18 22:45:32 UTC (rev 4282)
+++ MOAB/trunk/src/WriteUtil.cpp 2010-11-18 22:46:03 UTC (rev 4283)
@@ -495,7 +495,7 @@
if (conn_array == NULL) { // if it is structured mesh
ErrorCode rval;
int temp_buff_size = conn_size* sizeof(EntityHandle);
- for (int i = 0; i < count; i++) { // copy connectivity element by element
+ for (unsigned i = 0; i < count; i++) { // copy connectivity element by element
std::vector<EntityHandle> connect;
rval = static_cast<ElementSequence*>(*seq_iter)->get_connectivity(*iter,
connect);
Modified: MOAB/trunk/src/io/ReadSms.cpp
--- MOAB/trunk/src/io/ReadSms.cpp 2010-11-18 22:45:32 UTC (rev 4282)
+++ MOAB/trunk/src/io/ReadSms.cpp 2010-11-18 22:46:03 UTC (rev 4283)
@@ -480,7 +480,7 @@
ErrorCode ReadSms::read_parallel_info(FILE *file_ptr)
- ErrorCode result;
+// ErrorCode result;
// read partition info
int nparts, part_id, num_ifaces, num_corner_ents;
