[MOAB-dev] [Fathom] Why can't mbsize print dense tags?
    Tim Tautges
    tautges at mcs.anl.gov
    Tue Nov 16 15:30:45 CST 2010
Iulian, can you enter the bug described below as a ticket, and isolate in a small bit of code to make it easier to
debug?  Thanks.
- tim
On 11/16/2010 03:13 PM, Jason Kraftcheck wrote:
> On 11/16/2010 03:06 PM, Iulian Grindeanu wrote:
>> I am surprised that the
>> value shown for edges is 0 (not the default), but for the triangles it is
>> -1 (the default one).
> That is a bug.
>> It is true that the vtk file is not our format of choice.
>> Iulian ----- Original Message -----
>>> Hello, So if a dense tag is defined, is this meaning that all entity
>>> handles in the database have a value for that tag? (so , all vertices,
>>> all elements, all sets?)
> If a tag has a default value it is defined for all entities.
> If a tag is dense, then it may be defined for more entities than it was
> explicitly set on.  Which entities those are depends on MOAB's internal data
> representation.
> - jaosn
>>>> Since dense tags have a default value, it would be difficult to tell
>>>> whether a tag was actually set on the entity or if it was just
>>>> returning the default value. If there were a lot of tags on a mesh,
>>>> that output would be pretty large.
>>>> If you'd like to implement an option to mbsize that prints dense
>>>> tags too, that would be fine with me.
>>>> - tim
>>>> On 11/16/2010 12:37 PM, Robert Smith wrote:
>>>>> Mbsize -ll will print all sparse tags on an entity. It ends up
>>>>> using Core::print() to do this.
>>>>> Is there a reason only sparse tags are printed? All tags are
>>>>> retrieved but all but sparse are ignored. Is it an efficiency
>>>>> issue?
>>>>> Printing both types would make debugging somewhat easier. And
>>>>> mbsize would be showing ALL data in the file now.
>>>>> --Bob _______________________________________________ Fathom
>>>>> mailing list Fathom at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/fathom
>>>> "You will keep in perfect peace him whose mind is steadfast, because
>>>> he trusts in you." Isaiah 26:3
>>>> Tim Tautges Argonne National Laboratory (tautges at mcs.anl.gov)
>>>> (telecommuting from UW-Madison) phone: (608) 263-8485 1500
>>>> Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
>>>> _______________________________________________ Fathom mailing list
   steadfast, because he trusts in you."               Isaiah 26:3
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
