[MOAB-dev] [Fathom] Why can't mbsize print dense tags?
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Tue Nov 16 15:13:04 CST 2010
On 11/16/2010 03:06 PM, Iulian Grindeanu wrote:
> So, in a little experiment, when I used a dense tag only for vertices,
> the vtk file contains a SCALARS section just for vertices (even though I
> have elements in the model). If a just set the tag value for one triangle
> in the model, a new "SCALARS" section appears in the vtk file, for all
> "CELLS", including edges, and all triangles.
As you probably observed while reading the VTK file, there is no way to
store attribute data in a non-dense format.  The behavior you describe above
is dictated by the file format, and has nothing to do with what MOAB may or
may not store.
> I am surprised that the
> value shown for edges is 0 (not the default), but for the triangles it is
> -1 (the default one).
That is a bug.
> It is true that the vtk file is not our format of choice.
> Iulian ----- Original Message -----
>> Hello, So if a dense tag is defined, is this meaning that all entity
>> handles in the database have a value for that tag? (so , all vertices,
>> all elements, all sets?)
If a tag has a default value it is defined for all entities.
If a tag is dense, then it may be defined for more entities than it was
explicitly set on.  Which entities those are depends on MOAB's internal data
representation.
- jaosn
>>> Since dense tags have a default value, it would be difficult to tell
>>> whether a tag was actually set on the entity or if it was just
>>> returning the default value. If there were a lot of tags on a mesh,
>>> that output would be pretty large.
>>> If you'd like to implement an option to mbsize that prints dense
>>> tags too, that would be fine with me.
>>> - tim
>>> On 11/16/2010 12:37 PM, Robert Smith wrote:
>>>> Mbsize -ll will print all sparse tags on an entity. It ends up
>>>> using Core::print() to do this.
>>>> Is there a reason only sparse tags are printed? All tags are
>>>> retrieved but all but sparse are ignored. Is it an efficiency
>>>> issue?
>>>> Printing both types would make debugging somewhat easier. And
>>>> mbsize would be showing ALL data in the file now.
>>>> --Bob _______________________________________________ Fathom
>>>> mailing list Fathom at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/fathom
>>> "You will keep in perfect peace him whose mind is steadfast, because
>>> he trusts in you." Isaiah 26:3
>>> Tim Tautges Argonne National Laboratory (tautges at mcs.anl.gov)
>>> (telecommuting from UW-Madison) phone: (608) 263-8485 1500
>>> Engineering Dr. fax: (608) 263-4499 Madison, WI 53706
>>> _______________________________________________ Fathom mailing list
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
