[MOAB-dev] Building with zoltan
    Neil N. Carlson
    nnc at lanl.gov
    Tue Nov 16 11:06:28 CST 2010
I'm having trouble getting a parallel build of MOAB that includes
working mbpart/mbzoltan tools.  First off, does it matter where
the zoltan lib comes from?  I'm using the one that was built as
part of Trilinos 10.6, but there is also a 3.2 and 3.3 version
available independently from software.sandia.gov.  A colleague
said he used a zoltan out of the SEACAS tools from sourceforge.net.
Which one should I be using?  Second, what is the story with
parmetis (included in the zoltan distribution tarballs).  Is this
required?  My attempts so far have not included building this
library.
Any advice would be greatly appreciated!
-Neil
PS: Here's the output from running mbpart.  It appears to work
fine until the end when it tries to write the file.
% mbpart 2 1x1x4.g 1x1x4.h5m
Recursive Coordinate Bisection
Partitioning total time: 0.00773811 (secs)
Partitioning Statistics:
[ lots of stuff omitted ]
HDF5-DIAG: Error detected in HDF5 (1.8.5-patch1) MPI-process 0:
  #000: /opt/src/hdf5/hdf5-1.8.5-patch1/src/H5F.c line 1390 in H5Fcreate(): invalid file name
    major: Invalid arguments to routine
    minor: Bad value
1x1x4.h5m : failed to write file.
  Error code: MB_FAILURE (15)
  Error message: Failed to create file ""
