[MOAB-dev] Changing the options format in iMesh
Tim Tautges tautges at mcs.anl.gov
Mon Nov 15 17:49:59 CST 2010
On 11/15/2010 03:29 PM, James Porter wrote:
> On Mon, 2010-11-15 at 14:12 -0600, Tim Tautges wrote:
>> So how many of the failures are due to not supporting septahedrons?
> Here's a tentative list of what's failing for us in iMesh_unitTest. I'm
> not 100% sure about the reasons yet, but I'm reasonably confident:
> - (17) No support for septahedrons
Based on feedback from Mark Shephard, I think we'll be adding these.  Now I just need to remember where they're defined...
> - (19) Set ops (intersect, etc) don't seem to create a set of the type
>    passed in (i.e. same isList value)
This sounds like a MOAB bug to me; any comments?
> - (6) Set ops don't seem to work when one of the inputs is the root set
Another bug, since the result is a new set.
> - (18) Possible issues with iterators over sets with duplicate elements?
Argh, I probably originated the problem, I recall using ranges for iterators, which won't work for list-type sets.
- tim
> - (4) Some new tests with comments saying they're probably broken
> Stuff that's recently been fixed:
> - Option parsing
> - num_hops issues (-1 is now "infinite hops")
> - Returning proper error code when failing to delete an in-use tag
> With the above changes, we're up to 91% with 64 failures.
> - Jim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
