[MOAB-dev] r4267 - MOAB/trunk/itaps/imesh
jvporter at wisc.edu jvporter at wisc.edu
Mon Nov 15 15:22:46 CST 2010
Author: jvporter
Date: 2010-11-15 15:22:46 -0600 (Mon, 15 Nov 2010)
New Revision: 4267
Modified:
   MOAB/trunk/itaps/imesh/iMesh.h
   MOAB/trunk/itaps/imesh/iMesh_MOAB.cpp
Log:
* Change behavior of num_hops to agreed-upon spec (-1 = infinite hops)
* Return proper error code when failing to delete a tag
Modified: MOAB/trunk/itaps/imesh/iMesh.h
--- MOAB/trunk/itaps/imesh/iMesh.h	2010-11-15 19:48:45 UTC (rev 4266)
+++ MOAB/trunk/itaps/imesh/iMesh.h	2010-11-15 21:22:46 UTC (rev 4267)
@@ -770,11 +770,11 @@
      * Get the number of entity sets contained in a set or interface.  If
      * a set is input which is not the root set, num_hops indicates the
      * maximum number of contained sets from entity_set_handle to one of the
-     * contained sets, inclusive of the contained set.
+     * contained sets, not inclusive of the contained set.
      * \param instance iMesh instance handle
      * \param entity_set_handle Entity set being queried
      * \param num_hops Maximum hops from entity_set_handle to contained set,
-     *        inclusive of the contained set
+     *        not inclusive of the contained set
      * \param num_sets Pointer to the number of sets returned from function
      * \param *err Pointer to error type returned from function
@@ -790,11 +790,11 @@
      * Get the entity sets contained in a set or interface.  If
      * \param *contained_set_handles Pointer to array of set handles returned
      *        from function
      * \param contained_set_handles_allocated Pointer to allocated length of
@@ -997,12 +997,12 @@
     /**\brief  Get the number of child sets linked from a specified set
      * Get the number of child sets linked from a specified set.  If num_hops
-     * is non-zero, this represents the maximum hops from entity_set to any
+     * is not -1, this represents the maximum hops from entity_set to any
      * child in the count.
      * \param entity_set Entity set being queried
      * \param num_hops Maximum hops from entity_set_handle to child set,
-     *        inclusive of the child set
+     *        not inclusive of the child set
      * \param num_child Pointer to number of children returned from function
@@ -1015,12 +1015,12 @@
     /**\brief  Get the number of parent sets linked from a specified set
      * Get the number of parent sets linked from a specified set.  If num_hops
