[MOAB-dev] r4265 - MOAB/trunk/src/parallel/moab
tautges at mcs.anl.gov tautges at mcs.anl.gov
Mon Nov 15 12:32:39 CST 2010
Author: tautges
Date: 2010-11-15 12:32:39 -0600 (Mon, 15 Nov 2010)
New Revision: 4265
Modified:
   MOAB/trunk/src/parallel/moab/ParallelComm.hpp
Log:
Corrected comments on ParallelComm::get_shared_entities; also set DEBUG_BUFFER
to 0.
Modified: MOAB/trunk/src/parallel/moab/ParallelComm.hpp
--- MOAB/trunk/src/parallel/moab/ParallelComm.hpp	2010-11-12 18:45:20 UTC (rev 4264)
+++ MOAB/trunk/src/parallel/moab/ParallelComm.hpp	2010-11-15 18:32:39 UTC (rev 4265)
@@ -373,13 +373,14 @@
                                std::set<int> &procs,
                                int op = Interface::INTERSECT);
-    /** \brief Get entities on an inter-processor interface and of specified dimension
-     * If other_proc is -1, any interface entities are returned.  If dim is -1,
+    /** \brief Get shared entities of specified dimension
+     * If other_proc is -1, any shared entities are returned.  If dim is -1,
      * entities of all dimensions on interface are returned.
      * \param other_proc Rank of processor for which interface entities are requested
      * \param shared_ents Entities returned from function
      * \param dim Dimension of interface entities requested
      * \param iface If true, return only entities on the interface
+     * \param owned_filter If true, return only owned shared entities
   ErrorCode get_shared_entities(int other_proc,
                                   Range &shared_ents,
@@ -1133,7 +1134,7 @@
-#define DEBUG_BUFFER 1
+#define DEBUG_BUFFER 0
 inline void ParallelComm::Buffer::reserve(unsigned int new_size) {
