[MOAB-dev] Changing the options format in iMesh
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Nov 15 12:18:57 CST 2010
MOAB's should look like "silent;foobar".
- tim
On 11/15/2010 12:13 PM, James Porter wrote:
> In order to be compatible with the iMesh spec, we need to change the
> options format. Currently, it seems that MOAB uses the old iMesh-defined
> options syntax. Should we continue to support this syntax, or should
> MOAB use the new iMesh syntax? (Or maybe MOAB should have its own
> syntax?)
> For reference, the new way is "impl1:opt1 impl2:opt2", e.g. "moab:silent
> moab:foobar". If MOAB got its own syntax instead of just doing this, I'd
> expect the options to look like "silent foobar" by the time it got to
> MOAB. Options for other implementations would be stripped at the iMesh
> level.
> - Jim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
