[MOAB-dev] r4254 - MOAB/trunk/tools/mbzoltan
Tim Tautges
tautges at mcs.anl.gov
Fri Nov 5 11:15:52 CDT 2010
Thanks...
- tim
On 11/05/2010 11:13 AM, kraftche at cae.wisc.edu wrote:
> Author: kraftche
> Date: 2010-11-05 11:13:04 -0500 (Fri, 05 Nov 2010)
> New Revision: 4254
> Modified:
> MOAB/trunk/tools/mbzoltan/mbpart.cpp
> Log:
> fix some CL argument parsing bugs
> Modified: MOAB/trunk/tools/mbzoltan/mbpart.cpp
> --- MOAB/trunk/tools/mbzoltan/mbpart.cpp 2010-11-05 16:01:03 UTC (rev 4253)
> +++ MOAB/trunk/tools/mbzoltan/mbpart.cpp 2010-11-05 16:13:04 UTC (rev 4254)
> @@ -49,17 +49,19 @@
> Interface& mb = moab;
> MBZoltan tool(&mb, false, argc, argv);
> - int num_args = 0;
> + int num_args = 0; // number of non-flag arguments (e.g. input file, etc.)
> const char* args[3] = {0}; // non-flag options (num parts, input_file, output_file)
> const char* zoltan_method = DEFAULT_ZOLTAN_METHOD;
> const char* other_method = 0;
> - std::list<const char**> expected;
> + const char* imbal_tol_str = 0;
> + std::list<const char**> expected; // pointers to strings that should be set to arguments
> int i, j, part_dim = -1;
> long num_parts;
> bool write_sets = true, write_tags = false;
> bool no_more_flags = false;
> double imbal_tol = 1.10;
> + // Loop over each input argument
> for (i = 1; i< argc; ++i) {
> if (!expected.empty()) {
> if (!argv[i][0] || (!no_more_flags&& argv[i][0] == '-')) {
> @@ -70,6 +72,9 @@
> expected.pop_front();
> else if (!no_more_flags&& argv[i][0] == '-') {
> + // Loop over each flag, allowing multiple flags to
> + // be combined in a single argument (e.g. "-i 1.0 -b"
> + // can be specified as "-ib 1.0").
> for (j = 1; argv[i][j]; ++j) switch (argv[i][j]) {
> case 'h':
> help(argv[0]);
> @@ -81,14 +86,20 @@
> part_dim = argv[i][1] - '0';
> break;
> case 'z':
> + // note that we expect the zotlan_method to point to
> + // the next non-flag argument we encounter.
> expected.push_back(&zoltan_method);
> break;
> case 'p':
> zoltan_method = ZOLTAN_PARMETIS_METHOD;
> + // note that we expect the other_method to point to
> expected.push_back(&other_method);
> break;
> case 'o':
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
