[MOAB-dev] r4254 - MOAB/trunk/tools/mbzoltan
    kraftche at cae.wisc.edu
    Fri Nov  5 11:13:04 CDT 2010
Author: kraftche
Date: 2010-11-05 11:13:04 -0500 (Fri, 05 Nov 2010)
New Revision: 4254
Modified:
   MOAB/trunk/tools/mbzoltan/mbpart.cpp
Log:
fix some CL argument parsing bugs
Modified: MOAB/trunk/tools/mbzoltan/mbpart.cpp
--- MOAB/trunk/tools/mbzoltan/mbpart.cpp	2010-11-05 16:01:03 UTC (rev 4253)
+++ MOAB/trunk/tools/mbzoltan/mbpart.cpp	2010-11-05 16:13:04 UTC (rev 4254)
@@ -49,17 +49,19 @@
   Interface& mb = moab;
   MBZoltan tool(&mb, false, argc, argv);
-  int num_args = 0;
+  int num_args = 0; // number of non-flag arguments (e.g. input file, etc.)
   const char* args[3] = {0}; // non-flag options (num parts, input_file, output_file)
   const char* zoltan_method = DEFAULT_ZOLTAN_METHOD;
   const char* other_method = 0;
-  std::list<const char**> expected;
+  const char* imbal_tol_str = 0;
+  std::list<const char**> expected; // pointers to strings that should be set to arguments
   int i, j, part_dim = -1;
   long num_parts;
   bool write_sets = true, write_tags = false;
   bool no_more_flags = false;
   double imbal_tol = 1.10;
+    // Loop over each input argument
   for (i = 1; i < argc; ++i) {
     if (!expected.empty()) {
       if (!argv[i][0] || (!no_more_flags && argv[i][0] == '-')) {
@@ -70,6 +72,9 @@
       expected.pop_front();
     else if (!no_more_flags && argv[i][0] == '-') {
+        // Loop over each flag, allowing multiple flags to
+        // be combined in  a single argument (e.g. "-i 1.0 -b"
+        // can be specified as "-ib 1.0").
       for (j = 1; argv[i][j]; ++j) switch (argv[i][j]) {
         case 'h':
           help(argv[0]);
@@ -81,14 +86,20 @@
           part_dim = argv[i][1] - '0';
           break;
         case 'z':
+          // note that we expect the zotlan_method to point to
+          // the next non-flag argument we encounter.
           expected.push_back(&zoltan_method);
           break;
         case 'p':
           zoltan_method = ZOLTAN_PARMETIS_METHOD;
+          // note that we expect the other_method to point to
           expected.push_back(&other_method);
           break;
         case 'o':
