[MOAB-dev] MOAB API cleanup : get_connectivity
Jason Kraftcheck
kraftche at cae.wisc.edu
Mon Oct 25 08:44:08 CDT 2010
On 10/23/2010 05:55 PM, Tim Tautges wrote:
> I'm fine with all of those. Could you add a ticket to that effect?
> - tim
After reconsidering, I realized that the current get_connectivity functions
still provide some functionality that get_adjacencies cannot: getting
higher-order nodes (or not getting higher-order nodes. I forget which
get_adjacencies does.) We could handle that case in get_adjacencies by
passing some other, special value for the target dimension. But as it is no
longer just a matter of removing duplicate functionality it should probably
wait until after the release.
I did create ticket #170 for the offset list thing, though.
- jason
> On 10/22/2010 03:23 PM, Jason Kraftcheck wrote:
>> I think that, before the release, we should remove the following
>> functions
>> from MBInterface:
>> virtual ErrorCode get_connectivity(const EntityHandle
>> *entity_handles,
>> const int num_handles,
>> Range&connectivity,
>> bool topological_connectivity = false)
>> const;
>> virtual ErrorCode get_connectivity( const Range& entity_handles,
>> Range&connectivity,
>> const;
>> Both of these are mostly redundant because get_adjacencies can be used
>> for
>> exactly the same thing. The only time they would differ is if the input
>> list contained a mixture of polyhedra and other elements. But in that
>> case,
>> the behavior of get_adjacencies is probably both less confusing and
>> more useful.
>> Further, this function should accept an optional vector in which offsets
>> into the connectivity vector are stored:
>> *entity_handles,
>> std::vector<EntityHandle> &connectivity,
>> const;
>> While the offset vector isn't that important when getting only
>> topological
>> connectivity (verts per ent can be determined from only the type), if the
>> complete node list is requested for higher-order elements then this
>> function
>> isn't so useful without returning an offset list. Alternately, the final
>> optional argument could be removed and the function renamed as
>> 'get_topolgocial_connectivity'.
>> - jason
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
