[MOAB-dev] MOAB API cleanup : get_connectivity
Tim Tautges tautges at mcs.anl.gov
Sat Oct 23 17:55:56 CDT 2010
I'm fine with all of those.  Could you add a ticket to that effect?
- tim
On 10/22/2010 03:23 PM, Jason Kraftcheck wrote:
> I think that, before the release, we should remove the following functions
> from MBInterface:
>    virtual ErrorCode  get_connectivity(const EntityHandle *entity_handles,
>                                 const int num_handles,
>                                 Range&connectivity,
>                                 bool topological_connectivity = false) const;
>    virtual ErrorCode get_connectivity( const Range&  entity_handles,
>                                 Range&connectivity,
> Both of these are mostly redundant because get_adjacencies can be used for
> exactly the same thing.  The only time they would differ is if the input
> list contained a mixture of polyhedra and other elements.  But in that case,
> the behavior of get_adjacencies is probably both less confusing and more useful.
> Further, this function should accept an optional vector in which offsets
> into the connectivity vector are stored:
>                                 std::vector<EntityHandle>  &connectivity,
> While the offset vector isn't that important when getting only topological
> connectivity (verts per ent can be determined from only the type), if the
> complete node list is requested for higher-order elements then this function
> isn't so useful without returning an offset list.  Alternately, the final
> optional argument could be removed and the function renamed as
> 'get_topolgocial_connectivity'.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
