[MOAB-dev] r4212 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Tue Oct 12 08:12:51 CDT 2010
Author: kraftche
Date: 2010-10-12 08:12:51 -0500 (Tue, 12 Oct 2010)
New Revision: 4212
Modified:
MOAB/trunk/src/io/ReadHDF5.cpp
MOAB/trunk/src/io/ReadHDF5Dataset.cpp
Log:
fix typo in debug output
Modified: MOAB/trunk/src/io/ReadHDF5.cpp
--- MOAB/trunk/src/io/ReadHDF5.cpp 2010-10-11 21:37:28 UTC (rev 4211)
+++ MOAB/trunk/src/io/ReadHDF5.cpp 2010-10-12 13:12:51 UTC (rev 4212)
@@ -3154,7 +3154,7 @@
int nn = 0;
size_t offset = 0;
while (!val_reader.done()) {
- dbgOut.printf( 3, "Reading chunk %d of \"%s\" IDs\n", ++nn, tn.c_str() );
+ dbgOut.printf( 3, "Reading chunk %d of \"%s\" values\n", ++nn, tn.c_str() );
size_t count;
val_reader.read( dataBuffer, count );
if (MB_TYPE_HANDLE == mbtype) {
Modified: MOAB/trunk/src/io/ReadHDF5Dataset.cpp
--- MOAB/trunk/src/io/ReadHDF5Dataset.cpp 2010-10-11 21:37:28 UTC (rev 4211)
+++ MOAB/trunk/src/io/ReadHDF5Dataset.cpp 2010-10-12 13:12:51 UTC (rev 4212)
@@ -27,7 +27,7 @@
// Selection of hyperslabs appears to be superlinear. Don't try to select
// more than a few thousand at a time or things start to get real slow.
-const size_t DEFAULT_HYPERSLAB_SELECTION_LIMIT = 1000;
+const size_t DEFAULT_HYPERSLAB_SELECTION_LIMIT = 2500;
size_t ReadHDF5Dataset::hyperslabSelectionLimit = DEFAULT_HYPERSLAB_SELECTION_LIMIT;
void ReadHDF5Dataset::default_hyperslab_selection_limit()
{ hyperslabSelectionLimit = DEFAULT_HYPERSLAB_SELECTION_LIMIT; }
