[MOAB-dev] buildbot failure in Fathom on moab-par
    moab-dev at mcs.anl.gov
    Tue Oct 12 00:08:15 CDT 2010
The Fathomatic has detected a failed build of moab-par on Fathom.
Full details are available at:
 http://gnep.mcs.anl.gov:8010/builders/moab-par/builds/299
Buildbot URL: http://gnep.mcs.anl.gov:8010/
Buildslave for this Build: gnep
Build Reason: The Nightly scheduler named 'nightly' triggered this build
Build Source Stamp: None
Blamelist:
BUILD FAILED: failed test
LOG EXCERPT:
test_read : success
test_read : success
PASS: uber_parallel_test
PASS: scdtest
Warning: acis file has sequence numbers!
PASS: pcomm_serial
Running test_write_elements ...
Running test_write_shared_sets ...
Running test_var_length_parallel ...
Running test_read_elements ...
Running test_read_elements_by_rank ...
Running test_read_tags ...
Running test_read_global_tags ...
Running test_read_sets ...
PASS: parallel_hdf5_test
PASS: mhdf_parallel
Using default interval count: 2
01:   0.01: Generating mesh
01:   0.01: Resolving shared entities
01:   0.02: Beginning parallel write
00:   0.03: Generating mesh
00:   0.03: Resolving shared entities
00:   0.03: Beginning parallel write
Wrote 16 hexes in 0.01 seconds.
Wall time: generate: 0.000607967, resovle shared: 0.00162911, write_file: 0.0195479
00:   0.04: Removing written file
00:   0.04: Finalizing MPI
01:   0.03: Finalizing MPI
PASS: parallel_write_test
1 of 8 tests failed
sincerely,
 -The Fathomatic
