[MOAB-dev] r4195 - MOAB/trunk/test
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Wed Oct 6 11:56:13 CDT 2010
Author: kraftche
Date: 2010-10-06 11:56:13 -0500 (Wed, 06 Oct 2010)
New Revision: 4195
Modified:
   MOAB/trunk/test/TestRunner.hpp
Log:
clean up output text a little bit for tests
Modified: MOAB/trunk/test/TestRunner.hpp
--- MOAB/trunk/test/TestRunner.hpp	2010-10-06 16:54:46 UTC (rev 4194)
+++ MOAB/trunk/test/TestRunner.hpp	2010-10-06 16:56:13 UTC (rev 4195)
@@ -300,13 +300,13 @@
     printf("Skipped %d non-selected tests\n", (int)(RunnerTestCount - num_selected));
   else {
-    printf( "%2d registered tests\n", (int)RunnerTestCount );
+    printf( "%2d tests registered\n", (int)RunnerTestCount );
     if (num_selected == num_run)
-      printf( "%2d tests selected and ran\n", num_selected );
+      printf( "%2d tests selected\n", num_selected );
     else
-      printf( "%2d of %2d selected tests were ran\n", num_run, num_selected );
+      printf( "%2d of %2d tests ran\n", num_run, num_selected );
     if (num_run < (int)RunnerTestCount)
-      printf( "%2d of %2d registered tests skipped\n",
+      printf( "%2d of %2d tests skipped\n",
         (int)RunnerTestCount - num_run, (int)RunnerTestCount );
     printf( "%2d of %2d tests passed\n", num_run - fail_count, num_run );
     if (fail_count)
