[MOAB-dev] r4194 - in MOAB/trunk/src: . moab
kraftche at cae.wisc.edu
Wed Oct 6 11:54:46 CDT 2010
Author: kraftche
Date: 2010-10-06 11:54:46 -0500 (Wed, 06 Oct 2010)
New Revision: 4194
Modified:
MOAB/trunk/src/Range.cpp
MOAB/trunk/src/moab/Range.hpp
Log:
add Range::subset_by_dimension(int)
Modified: MOAB/trunk/src/Range.cpp
--- MOAB/trunk/src/Range.cpp 2010-10-06 00:29:16 UTC (rev 4193)
+++ MOAB/trunk/src/Range.cpp 2010-10-06 16:54:46 UTC (rev 4194)
@@ -995,6 +995,26 @@
return result;
+ //! return a subset of this range, by type
+Range Range::subset_by_dimension( int d ) const
+ EntityHandle handle1 = CREATE_HANDLE( CN::TypeDimensionMap[d].first, 0 );
+ iterator st = lower_bound( begin(), end(), handle1 );
+ iterator en;
+ if (d < 4) { // dimension 4 is MBENTITYSET
+ EntityHandle handle2 = CREATE_HANDLE( CN::TypeDimensionMap[d+1].first, 0 );
+ iterator en = lower_bound( st, end(), handle2 );
+ else {
+ en = end();
+ Range result;
+ result.insert( st, en );
+ return result;
bool operator==( const Range& r1, const Range& r2 )
Range::const_pair_iterator i1, i2;
Modified: MOAB/trunk/src/moab/Range.hpp
--- MOAB/trunk/src/moab/Range.hpp 2010-10-06 00:29:16 UTC (rev 4193)
+++ MOAB/trunk/src/moab/Range.hpp 2010-10-06 16:54:46 UTC (rev 4194)
@@ -349,6 +349,9 @@
Range subset_by_type(EntityType t) const;
+ //! return a subset of this range, by dimension
+ Range subset_by_dimension(int dim) const;
struct PairNode : public std::pair<EntityHandle,EntityHandle>
