[MOAB-dev] NAME_TAG_SIZE value?
Jason Kraftcheck
kraftche at cae.wisc.edu
Mon Sep 27 16:20:00 CDT 2010
On 09/27/2010 04:09 PM, Tim Tautges wrote:
> Ok, go ahead and set it to 64. But, also run the code through valgrind
> to make sure it isn't something else, it can be dangerous doing string
> reads/writes (buffer overflows, etc.).
This may have some unpleasant side effects. If the tag is created by a file
read, then you'll have a situation where the constant is 64 but the actual
tag size is 32. If the tag is created by MOAB first, then attempts to read
files also containing the tag will fail because of the size mismatch.
- jason
> - tim
> On 09/27/2010 03:41 PM, Rajeev Jain wrote:
>> Why is the NAME_TAG_SIZE variable in MBTagConventions.hpp is set to 32?
>> This caused mbsize to fail in Tqdcfr::parse_acis_attribs when I was
>> reading a .cub file. It fails around memcpy step in Tqdcfr:2264. On
>> increasing NAME_TAG_SIZE to 64 the mbsize/mbconvert works.
>> The .cub file is at /homes/jain/MeshKit-acis/rgg/Justin/fc33.cub. I need
>> to make this work, so that mbsize/mbconvert doesn't seg-fault with this
>> .cub file.
>> Rajeev
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
