[MOAB-dev] NAME_TAG_SIZE value?
    Tim Tautges
    tautges at mcs.anl.gov
    Mon Sep 27 16:09:04 CDT 2010
Ok, go ahead and set it to 64.  But, also run the code through valgrind to make sure it isn't something else, it can be
dangerous doing string reads/writes (buffer overflows, etc.).
- tim
On 09/27/2010 03:41 PM, Rajeev Jain wrote:
> Why is the NAME_TAG_SIZE variable in MBTagConventions.hpp is set to 32?
> This caused mbsize to fail in Tqdcfr::parse_acis_attribs when I was
> reading a .cub file. It fails around memcpy step in Tqdcfr:2264. On
> increasing NAME_TAG_SIZE to 64 the mbsize/mbconvert works.
> The .cub file is at /homes/jain/MeshKit-acis/rgg/Justin/fc33.cub. I need
> to make this work, so that mbsize/mbconvert doesn't seg-fault with this
> .cub file.
> Rajeev
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
