[MOAB-dev] portability issue/question
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Thu Jul 29 08:06:56 CDT 2010
On 07/29/2010 07:00 AM, Paul Wilson wrote:
> Hello,
> I am integrating MOAB/DAGMC into a c++ code that includes a header that
> defines index() as a macro, apparently through some combination of
> system headers.
That's really ugly.  It comes from a system header???
> This creates a problem with including moab/Range.hpp
> because it attempts to define a member function index().
It also has an argument named 'index' in one spot.
> Fortunately it
> creates a compile time failure because the signature of the
> Range::index() is different from the macro, otherwise who knows what
> would happen???
> I haven't bothered to track it down yet, but the short solution has been
> to add the following immediately prior to the include:
> #ifdef index
> #undef index
> #endif
> I have resisted committing this to the repo because it seems like a
> little presumptious/overbearing. Any other solutions?
In general, I can't think of a better way to work around really poor
macro name choices like this.  Undef whatever you need to right after
including the offending header.  Or if you need to include the offending
header in more than one place, write a wrapper header that includes it
and any necessary #undefs.
The ideal solution would be to fix the offending header, but I assume
that isn't an option.
One extreme solution would be to remove the two offending functions from
moab::Range.  Normally I wouldn't even mention this, but I don't
particularly like these two functions.  The STL only provides
index-based access for containers when the implementation it is O(1).
It could potentially be O(n) for Range, leading people to accidentally
write O(n^2) code.  These things could be done the same as one would for
std::list (or for the index() method, almost any container): replace
"range[i]" with "*(range.begin()+i)" and "range.index(h)" with
"range.find(h)-range.begin()".  But the need for either should be rather
obscure.  I'm having trouble imagining a case where it wouldn't be more
efficient to work with iterators rather than indices.
- jason
