[MOAB-dev] portability issue/question
Paul Wilson
wilsonp at engr.wisc.edu
Thu Jul 29 07:00:57 CDT 2010
Hello,
I am integrating MOAB/DAGMC into a c++ code that includes a header that
defines index() as a macro, apparently through some combination of
system headers.
This creates a problem with including moab/Range.hpp because it attempts
to define a member function index(). Fortunately it creates a compile
time failure because the signature of the Range::index() is different
from the macro, otherwise who knows what would happen???
I haven't bothered to track it down yet, but the short solution has been
to add the following immediately prior to the include:
#ifdef index
#undef index
#endif
I have resisted committing this to the repo because it seems like a
little presumptious/overbearing. Any other solutions?
Paul
Paul Wilson
Paul P.H. Wilson 419 Engineering Research Building
wilsonp at engr.wisc.edu 1500 Engineering Dr
ph/fax: 608/263-0807 Madison, WI 53706
My calendar: http://bit.ly/pphw-calendar
Computational Nuclear Engineering Research Group
http://cnerg.engr.wisc.edu
Associate Professor, Nuclear Engineering
Engineering Physics Department
http://www.engr.wisc.edu/ep
Chair, Energy Analysis & Policy Certificate
Nelson Institute for Environmental Studies
http://nelson.wisc.edu/eap/
Contributing to the joy and improvement
of all those around me
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100729/3385b96f/attachment.bin>
