[MOAB-dev] parallel write
Lukasz Kaczmarczyk
likask at civil.gla.ac.uk
Fri Jul 2 10:01:10 CDT 2010
Thanks for answer, it looks that MPI-IO not working well with NFS system.
As a solution, I use sequential writting and gather information about meshset on root node. This will not work for extremally larg meshes but is ok for me. I think that you should consider such option in MOAB implementation. This is how I do it now, it is far from pefect, but works,
mbImpl->create_meshset(MESHSET_SET,outset);
gather_PostProcTrefftzMeshSet_entities(ElemTrefftzMeshSet,outset,3);
if((int)mbpc->proc_config().proc_rank() == 0)
result = mbImpl->write_file(file,0,0,&outset,1,tag_list,2); EE(mbImpl) RR
mbImpl->clear_meshset(&outset,1);
mbImpl->delete_entities(&outset,1);
void FETrefftzShell::gather_PostProcTrefftzMeshSet_entities(MBEntityHandle inset,MBEntityHandle outset,int dim) {
MBRange entities_to_gather;
mbImpl->get_entities_by_dimension(inset,3,entities_to_gather);
if ((int)mbpc->proc_config().proc_rank() == 0) {
mbImpl->add_entities(outset,entities_to_gather);
int buff_size,success;
MPI_Status status;
MBParallelComm::Buffer buff(INITIAL_BUFF_SIZE);
buff.reset_ptr(sizeof(int));
for( unsigned int rr = 1; rr<mbpc->proc_config().proc_size(); rr++) {
if ((int)mbpc->proc_config().proc_rank() == rr) {
add_verts(entities_to_gather);
RRA("Failed to add adj vertices.");
result = mbpc->pack_buffer( entities_to_gather, false, true,
false, -1, &buff);
RRA("Failed to compute buffer size in broadcast_entities.");
buff.set_stored_size();
buff_size = buff.buff_ptr - buff.mem_ptr;
success = MPI_Ssend(&buff_size, 1, MPI_INT, 0, 100+rr, mbpc->proc_config().proc_comm() );
if (MPI_SUCCESS != success) {
result = MB_FAILURE;
RRA("MPI_Send of buffer size failed.");
} else if( (int)mbpc->proc_config().proc_rank() == 0 ) {
success = MPI_Recv(&buff_size, 1, MPI_INT, rr, 100+rr, mbpc->proc_config().proc_comm(), &status);
RRA("MPI_Recive of buffer size failed.");
if (!buff_size) continue; //no data
size_t offset = 0;
while (buff_size) {
int size = std::min( buff_size, MAX_BCAST_SIZE );
buff.reserve(buff_size);
if( (int)mbpc->proc_config().proc_rank() == rr ) {
success = MPI_Ssend(buff.mem_ptr, size, MPI_UNSIGNED_CHAR, 0, 1000+rr, mbpc->proc_config().proc_comm() );
RRA("MPI_Send of buffer size failed."); }
success = MPI_Recv(buff.mem_ptr, size, MPI_UNSIGNED_CHAR, rr, 1000+rr, mbpc->proc_config().proc_comm(), &status );
offset += size;
buff_size -= size;
MBRange entities_recived;
std::vector<std::vector<EntityHandle> > dum1a, dum1b;
std::vector<std::vector<int> > dum1p;
std::vector<EntityHandle> dum2;
std::vector<unsigned int> dum3;
result = mbpc->unpack_buffer(buff.buff_ptr, false, rr, -1,
dum1a, dum1b, dum1p, dum2, dum2, dum3, entities_recived);
RRA("Failed to unpack buffer in broadcast_entities.");
mbImpl->add_entities(outset,entities_recived);
return;
On 2 Jul 2010, at 15:06, Jason Kraftcheck wrote:
> Lukasz Kaczmarczyk wrote:
>> Hello,
>> I do parallel write to moab file format. I get random error related. Do you have idea what is a reason of this problem? Or how I can overcome this. It is easy way to gather mesh/meshset on one processor and then do writing?
> I have not seen that particular error before. As the library reports it as
> "Internal error (too specific to document in detail)" and "Some MPI function
> failed", my first guess would be that there is some problem with the HDF5
> library or the underlying MPI-IO implementation.
> - jason
