[MOAB-dev] parallel write
Jason Kraftcheck kraftche at cae.wisc.edu
Fri Jul 2 09:06:02 CDT 2010
Lukasz Kaczmarczyk wrote:
> Hello,
> I do parallel write to moab file format.  I get random error related. Do you have idea what is a reason of this problem? Or how I can overcome this.  It is easy way to gather mesh/meshset on one processor and then do writing?
I have not seen that particular error before.  As the library reports it as
"Internal error (too specific to document in detail)" and "Some MPI function
failed", my first guess would be that there is some problem with the HDF5
library or the underlying MPI-IO implementation.
- jason
