[MOAB-dev] Trouble buildng MOAB
James Porter jvporter at wisc.edu
Wed Jun 9 14:43:05 CDT 2010
On Wed, 2010-06-09 at 13:37 -0500, Thomas, Justin W. wrote:
> Thanks for your help, now I am moving to the next problem. ;)
> I rebuilt a serial version of CGM, and built a serial, no-CGM version of MOAB. This was successful, and the make-checks for both CGM and MOAB were fine. Now I just tried doing Lasso, but the make-check fails. Here is my configure line:
> ./configure --prefix=/Software/Lasso --with-igeom=/Software/CGM/serial/gcc --with-imesh=/Software/MOAB/serial/gcc --disable-optimize --enable-debug
> I attached the output of configure, make, and make check. If you have any suggestions, I would greatly appreciate it.
Can you try configuring without --disable-optimize and --enable-debug,
just to see what happens? We run nightly tests with that configuration,
and the tests pass, so it might be an issue with the config you're
using.
- Jim
