[MOAB-dev] Trouble buildng MOAB
Thomas, Justin W.
jthomas at anl.gov
Wed Jun 9 13:37:24 CDT 2010
Thanks for your help, now I am moving to the next problem. ;)
I rebuilt a serial version of CGM, and built a serial, no-CGM version of MOAB. This was successful, and the make-checks for both CGM and MOAB were fine. Now I just tried doing Lasso, but the make-check fails. Here is my configure line:
./configure --prefix=/Software/Lasso --with-igeom=/Software/CGM/serial/gcc --with-imesh=/Software/MOAB/serial/gcc --disable-optimize --enable-debug
I attached the output of configure, make, and make check. If you have any suggestions, I would greatly appreciate it.
Justin
From: moab-dev-bounces at mcs.anl.gov [moab-dev-bounces at mcs.anl.gov] On Behalf Of Thomas, Justin W. [jthomas at anl.gov]
Sent: Wednesday, June 09, 2010 1:10 PM
To: moab-dev at mcs.anl.gov
Subject: Re: [MOAB-dev] Trouble buildng MOAB
If this helps...
If I remove MPI and CGM from my MOAB build, then the make check is successful.
On 6/9/10 12:24 PM, "Justin Thomas" <jthomas at anl.gov> wrote:
Hello,
I have been trying to install MOAB on a Linux x86_64 workstation, but have
had no success so far. I am building with CGM and Cubit. I have tried both
the version in the repo, and the most recent nightly tarball. They failed
with very similar (identical as far as I can tell) symptoms: configuration
and building seemed successful, but the make check failed. If you have any
suggestions, I would be glad to hear them.
Machine details:
arch: x86_64
uname -a:Linux palmer.ne.anl.gov 2.6.18-194.3.1.el5 #1 SMP Thu May 13
13:08:30 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
gcc: 4.1.2
make: GNU Make 3.81
autotools:
autoreconf (GNU Autoconf) 2.65
automake (GNU automake) 1.11
libtool (GNU libtool) 2.2.8
dependencies:
CGM: from SVN
MPI: MPICH-2 1.2.1p1 compiled with gcc
NetCDF: 3.6.3
HDF5: 1.8.2
zlib: 1.2.5
szip: 2.1
Configure command:
./configure --prefix=/Software/MOAB/parallel/gcc
--with-cgm=/Software/CGM/parallel/gcc
--with-mpi=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin
--with-netcdf=/Software/visit1.12.1/visit/netcdf/3.6.3/linux-x86_64_gcc-4.1.
2 --with-hdf5=/Software/visit1.12.1/visit/hdf5/1.8.2/linux-x86_64_gcc-4.1.2
--with-zlib=/Software/zlib-1.2.5/gcc
--with-szip=/Software/visit1.12.1/visit/szip/2.1/linux-x86_64_gcc-4.1.2
--disable-production CC=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpicc
CXX=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpicxx
F77=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpif77
FC=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpif90
F90=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpif90 --disable-optimize
--disable-debug
I attached the output/logs for configure, make, and make check.
I suppose the next thing to try would be to install the latest gcc. Besides
that, any other ideas? Many thanks...
Justin
Justin W. Thomas
Nuclear Engineering Division
Argonne National Laboratory
9700 South Cass Avenue Bldg 208
Argonne, IL 60439
Phone: (630) 252-4850
Fax: (630) 252-3361
Justin W. Thomas
Argonne, IL 60439
Fax: (630) 252-3361
Justin W. Thomas
Argonne, IL 60439
Fax: (630) 252-3361
Type: application/x-gzip
Desc: lasso_email.tar.gz
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100609/76bb636e/attachment.bin>
