[MOAB-dev] Trouble buildng MOAB
    Thomas, Justin W.
    jthomas at anl.gov
    Wed Jun  9 12:24:36 CDT 2010
Hello,
I have been trying to install MOAB on a Linux x86_64 workstation, but have
had no success so far. I am building with CGM and Cubit. I have tried both
the version in the repo, and the most recent nightly tarball. They failed
with very similar (identical as far as I can tell) symptoms: configuration
and building seemed successful, but the make check failed. If you have any
suggestions, I would be glad to hear them.
Machine details:
arch: x86_64
uname -a:Linux palmer.ne.anl.gov 2.6.18-194.3.1.el5 #1 SMP Thu May 13
13:08:30 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux
gcc: 4.1.2
make: GNU Make 3.81
autotools:
autoreconf (GNU Autoconf) 2.65
automake (GNU automake) 1.11
libtool (GNU libtool) 2.2.8
dependencies:
CGM: from SVN
MPI: MPICH-2 1.2.1p1 compiled with gcc
NetCDF: 3.6.3
HDF5: 1.8.2
zlib: 1.2.5
szip: 2.1
Configure command:
./configure --prefix=/Software/MOAB/parallel/gcc
--with-cgm=/Software/CGM/parallel/gcc
--with-mpi=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin
--with-netcdf=/Software/visit1.12.1/visit/netcdf/3.6.3/linux-x86_64_gcc-4.1.
2 --with-hdf5=/Software/visit1.12.1/visit/hdf5/1.8.2/linux-x86_64_gcc-4.1.2
--with-zlib=/Software/zlib-1.2.5/gcc
--with-szip=/Software/visit1.12.1/visit/szip/2.1/linux-x86_64_gcc-4.1.2
--disable-production CC=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpicc
CXX=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpicxx
F77=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpif77
FC=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpif90
F90=/Software/mpich2-1.2.1p1-gcc-4.1.2/bin/mpif90 --disable-optimize
--disable-debug
I attached the output/logs for configure, make, and make check.
I suppose the next thing to try would be to install the latest gcc. Besides
that, any other ideas? Many thanks...
Justin
___________________________________
Justin W. Thomas
Nuclear Engineering Division
Argonne National Laboratory
9700 South Cass Avenue Bldg 208
Argonne, IL 60439
Phone: (630) 252-4850
Fax: (630) 252-3361
Justin W. Thomas
Argonne, IL 60439
Fax: (630) 252-3361
Desc: make.check[1].log
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100609/b8d794d9/attachment-0003.obj>
Desc: config[1].log
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100609/b8d794d9/attachment-0004.obj>
Desc: make[1].log
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20100609/b8d794d9/attachment-0005.obj>
