[MOAB-dev] r3995 - MOAB/trunk/src
Julien Vignollet vignollet at civil.gla.ac.uk
Thu Jun 3 17:53:14 CDT 2010
It seems to be working great now, thank you!
Julien
On 3 Jun 2010, at 23:24, <iulian at mcs.anl.gov> wrote:
> Author: iulian
> Date: 2010-06-03 17:24:34 -0500 (Thu, 03 Jun 2010)
> New Revision: 3995
> Modified:
>   MOAB/trunk/src/MBCNArrays.hpp
> Log:
> the higher order element face connectivity is decided from face - edge
> adjacency.
> More tests and checks may be necessary, or, as Jason suggested, simplify
> the maintenance by eliminating the need for CN::mConnectivityMap
> Modified: MOAB/trunk/src/MBCNArrays.hpp
> --- MOAB/trunk/src/MBCNArrays.hpp	2010-06-02 20:14:49 UTC (rev 3994)
> +++ MOAB/trunk/src/MBCNArrays.hpp	2010-06-03 22:24:34 UTC (rev 3995)
> @@ -397,13 +397,13 @@
>     { // source dim 2
>       { // target dim 0
>         {3, 3, 3, 3}, // 3 vertices for all faces
> -        {{0,1,3}, {1,2,3}, {0,2,3}, {0,1,2}} }, // end target dim 0
> +        {{0,1,3}, {1,2,3}, {0,3,2}, {0,2,1}} }, // end target dim 0
>       { // target dim 1
>         {3, 3, 3, 3}, // 3 edges for all faces
> -        {{0,4,3}, {1,5,4}, {2,3,5}, {0,2,1}} }, // end target dim 1
> +        {{0,4,3}, {1,5,4}, {3,5,2}, {2,1,0}} }, // end target dim 1
>       { // target dim 2
>         {3, 3, 3, 3}, // 3 faces for all faces
> -        {{3,1,2}, {3,2,0}, {0,1,3}, {0,2,1}} }, // end target dim 2
> +        {{3,1,2}, {3,2,0}, {0,1,3}, {2,1,0}} }, // end target dim 2
>       { // target dimension 3
>         {1, 1, 1, 1}, // 0 connected elements for all vertices
>         {{0}, {0}, {0}, {0}} } // end target dimension 3
