[MOAB-dev] r3995 - MOAB/trunk/src
iulian at mcs.anl.gov iulian at mcs.anl.gov
Thu Jun 3 17:24:35 CDT 2010
Author: iulian
Date: 2010-06-03 17:24:34 -0500 (Thu, 03 Jun 2010)
New Revision: 3995
Modified:
   MOAB/trunk/src/MBCNArrays.hpp
Log:
the higher order element face connectivity is decided from face - edge
adjacency.
More tests and checks may be necessary, or, as Jason suggested, simplify
the maintenance by eliminating the need for CN::mConnectivityMap
Modified: MOAB/trunk/src/MBCNArrays.hpp
--- MOAB/trunk/src/MBCNArrays.hpp	2010-06-02 20:14:49 UTC (rev 3994)
+++ MOAB/trunk/src/MBCNArrays.hpp	2010-06-03 22:24:34 UTC (rev 3995)
@@ -397,13 +397,13 @@
     { // source dim 2
       { // target dim 0
         {3, 3, 3, 3}, // 3 vertices for all faces
-        {{0,1,3}, {1,2,3}, {0,2,3}, {0,1,2}} }, // end target dim 0
+        {{0,1,3}, {1,2,3}, {0,3,2}, {0,2,1}} }, // end target dim 0
       { // target dim 1
         {3, 3, 3, 3}, // 3 edges for all faces
-        {{0,4,3}, {1,5,4}, {2,3,5}, {0,2,1}} }, // end target dim 1
+        {{0,4,3}, {1,5,4}, {3,5,2}, {2,1,0}} }, // end target dim 1
       { // target dim 2
         {3, 3, 3, 3}, // 3 faces for all faces
-        {{3,1,2}, {3,2,0}, {0,1,3}, {0,2,1}} }, // end target dim 2
+        {{3,1,2}, {3,2,0}, {0,1,3}, {2,1,0}} }, // end target dim 2
       { // target dimension 3
         {1, 1, 1, 1}, // 0 connected elements for all vertices
         {{0}, {0}, {0}, {0}} } // end target dimension 3
