[MOAB-dev] Order of entities in unordered entity sets?
smithrm-mcs at zimbra.anl.gov
Tue Jun 1 19:04:13 CDT 2010
Am I missing something here? I thought sets were unordered but no duplicates and lists are ordered but can have duplicates. if isList=false shouldn't that mean its not a list and so not ordered as Jim said?
--Bob
Sent from my Verizon Wireless BlackBerry
-----Original Message-----
Date: Tue, 01 Jun 2010 18:31:32
To: <moab-dev at mcs.anl.gov>
Subject: Re: [MOAB-dev] Order of entities in unordered entity sets?
Um, if isList=false, the set should be ordered. If it is unordered, isList should be true, which means it is NOT stored
in order. Basically, an iMesh set is either a set or a list.
- tim
On 06/01/2010 06:05 PM, James Porter wrote:
> Hey all,
> I was under the impression that unordered entity sets (isList=false) in
> MOAB store their entities in sorted order, which means that they're also
> sorted by dimension. However, I'm seeing vertices stored *after* edges
> and faces in some code from MeshKit. If this is a bug, I'll see if I can
> come up with a minimal test-case that fails, but I wanted to make sure
> I'm not going crazy first.
> - Jim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
