[MOAB-dev] r3984 - MOAB/trunk/src/io
kraftche at cae.wisc.edu
Tue Jun 1 08:00:01 CDT 2010
Author: kraftche
Date: 2010-06-01 08:00:01 -0500 (Tue, 01 Jun 2010)
New Revision: 3984
Modified:
MOAB/trunk/src/io/GmshUtil.cpp
Log:
Fix GMsh file format Tet10 node order
Modified: MOAB/trunk/src/io/GmshUtil.cpp
--- MOAB/trunk/src/io/GmshUtil.cpp 2010-05-30 00:02:15 UTC (rev 3983)
+++ MOAB/trunk/src/io/GmshUtil.cpp 2010-06-01 13:00:01 UTC (rev 3984)
@@ -24,6 +24,12 @@
8, 11, 12, 9, 13, 10, 14, 15, 16, 19, 17, 18, // edges
24, 20, 23, 21, 22, 25, // faces
26 }; // volume
+const int tet_10_node_order[] = {
+ 0, 1, 2, 3,
+ 4, 5, 6,
+ 7, 9, 8 };
// Indexed by position in MOAB order, containing cooresponding
// position in Gmsh order.
const int pri_15_node_order[] = {
@@ -49,7 +55,7 @@
{ "2nd order line", 8, MBEDGE, 3, 0 },
{ "2nd order triangle", 9, MBTRI, 6, 0 },
{ "2nd order quadrangle", 10, MBQUAD, 9, 0 },
- { "2nd order tetrahedron", 11, MBTET, 10, 0 },
+ { "2nd order tetrahedron", 11, MBTET, 10, tet_10_node_order },
{ "2nd order hexahedron", 12, MBHEX, 27, hex_27_node_order },
{ "2nd order prism", 13, MBMAXTYPE, 0, 0 }, // prism w/ mid-face nodes on quads but not tris
{ "2nd order pyramid", 14, MBMAXTYPE, 0, 0 }, // pyramid w/ mid-face nodes on quad but not tris
