[MOAB-dev] r3951 - in MOAB/trunk: src/io tools
tautges at mcs.anl.gov
Tue May 25 11:03:11 CDT 2010
Author: tautges
Date: 2010-05-25 11:03:11 -0500 (Tue, 25 May 2010)
New Revision: 3951
Modified:
MOAB/trunk/src/io/ReadCCMIO.cpp
MOAB/trunk/tools/size.cpp
Log:
Account for default material sets with index = 0 in CCMIO.
Fix bug in size evaluating meshes with polyhedra.
Modified: MOAB/trunk/src/io/ReadCCMIO.cpp
--- MOAB/trunk/src/io/ReadCCMIO.cpp 2010-05-25 15:02:33 UTC (rev 3950)
+++ MOAB/trunk/src/io/ReadCCMIO.cpp 2010-05-25 16:03:11 UTC (rev 3951)
@@ -349,7 +349,7 @@
int mindex;
CCMIOError error = kCCMIONoErr;
CCMIOGetEntityIndex(&error, next, &mindex);
- assert(mindex > 0 && mindex <= (int)newNeusets.size()+1);
+ assert(mindex >= 0 && mindex <= (int)newNeusets.size()+1);
std::map<int,EntityHandle>::iterator mit = newNeusets.find(mindex);
if (mit == newNeusets.end())
// no actual faces for this neuset; continue to next
@@ -489,13 +489,13 @@
// first, do a dummy read to see if we even have topo types in this mesh
int dum_int;
CCMIOReadOpt1i(&error, cellID, "CellTopologyType", &dum_int,
- CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOStart));
+ CCMIOINDEXC(kCCMIOStart), CCMIOINDEXC(kCCMIOStart)+1);
if (kCCMIONoErr != error) return MB_SUCCESS;
// ok, we have topo types; first get the map node
std::vector<int> dum_ints(num_cells);
CCMIOReadCells(&error, cellID, &mapID, &dum_ints[0],
CHKCCMERR(error, "Failed to get the map node.");
// now read the map
Modified: MOAB/trunk/tools/size.cpp
--- MOAB/trunk/tools/size.cpp 2010-05-25 15:02:33 UTC (rev 3950)
+++ MOAB/trunk/tools/size.cpp 2010-05-25 16:03:11 UTC (rev 3951)
@@ -146,9 +146,14 @@
rval = mb.get_connectivity( &*i, 1, conn, true );
if (MB_SUCCESS != rval) return rval;
+ if (type == MBPOLYHEDRON) {
+ std::vector<EntityHandle> dum_conn(conn);
+ conn.clear();
+ rval = mb.get_adjacencies(&dum_conn[0], dum_conn.size(), 0, false, conn, Interface::UNION);
+ if (MB_SUCCESS != rval) return rval;
coords.resize( 3*conn.size() );
rval = mb.get_coords( &conn[0], conn.size(), &coords[0] );
- if (MB_SUCCESS != rval) return rval;
stats.stats[type].add( measure( type, conn.size(), &coords[0] ) );
if (type != MBEDGE)
