Author: kraftche
Date: 2010-05-25 10:02:33 -0500 (Tue, 25 May 2010)
New Revision: 3950
Modified:
MOAB/trunk/src/io/WriteHDF5.cpp
MOAB/trunk/src/io/WriteHDF5.hpp
MOAB/trunk/src/io/mhdf/src/nodes.c
MOAB/trunk/src/parallel/WriteHDF5Parallel.cpp
Log:
fix bug in coordinate chunking code for h5m files, and add an string option to enable the capability
Modified: MOAB/trunk/src/io/WriteHDF5.cpp
--- MOAB/trunk/src/io/WriteHDF5.cpp 2010-05-25 14:20:18 UTC (rev 3949)
+++ MOAB/trunk/src/io/WriteHDF5.cpp 2010-05-25 15:02:33 UTC (rev 3950)
@@ -307,6 +307,7 @@
parallelWrite(false),
collectiveIO(false),
writeTagDense(false),
+ chunkNodes(false),
writeProp( H5P_DEFAULT ),
dbgOut("H5M ", stderr)
@@ -386,6 +387,7 @@
writeTagDense = (MB_SUCCESS == opts.get_null_option("DENSE_TAGS"));
+ chunkNodes = (MB_SUCCESS == opts.get_null_option("CHUNK_NODES"));
// Enable some extra checks for reads. Note: amongst other things this
@@ -2177,7 +2179,7 @@
if (nodeSet.range.size()) {
nodeSet.total_num_ents = nodeSet.range.size();
handle = mhdf_createNodeCoords( filePtr, dimension, nodeSet.total_num_ents,
- &first_id, false, &status );
+ &first_id, chunkNodes, &status );
CHK_MHDF_ERR_0(status);
mhdf_closeData( filePtr, handle, &status );
Modified: MOAB/trunk/src/io/WriteHDF5.hpp
--- MOAB/trunk/src/io/WriteHDF5.hpp 2010-05-25 14:20:18 UTC (rev 3949)
+++ MOAB/trunk/src/io/WriteHDF5.hpp 2010-05-25 15:02:33 UTC (rev 3950)
@@ -304,6 +304,8 @@
bool collectiveIO;
//! True if writing dense-formatted tag data
bool writeTagDense;
+ //! True if using chunking in on-disk layout of node coordinate data
+ bool chunkNodes;
//! Property set to pass to H5Dwrite calls.
//! For serial, should be H5P_DEFAULTS.
Modified: MOAB/trunk/src/io/mhdf/src/nodes.c
--- MOAB/trunk/src/io/mhdf/src/nodes.c 2010-05-25 14:20:18 UTC (rev 3949)
+++ MOAB/trunk/src/io/mhdf/src/nodes.c 2010-05-25 15:02:33 UTC (rev 3950)
@@ -23,6 +23,7 @@
#include "util.h"
#include "file-handle.h"
