[MOAB-dev] r3919 - in MOAB/trunk: MeshFiles/unittest	MeshFiles/unittest/io test test/io test/parallel
    Robert Smith
    smithrm at mcs.anl.gov
    Wed May 19 15:24:53 CDT 2010
I think there may be a problem.  MBTest.cpp::mb_stress_test is looking
for mb_big_test.g but it can't find the file.  Does this test need to
be updated to look in the new directory?  I see that the .gz file gets
unzipped there during make check but the test still can't find it.
--Bob
On May 19, 2010, at 11:06 AM, tautges at mcs.anl.gov wrote:
> Author: tautges
> Date: 2010-05-19 11:06:47 -0500 (Wed, 19 May 2010)
> New Revision: 3919
> Added:
>   MOAB/trunk/MeshFiles/unittest/125hex.g
>   MOAB/trunk/MeshFiles/unittest/1hex.g
>   MOAB/trunk/MeshFiles/unittest/1khex.g
>   MOAB/trunk/MeshFiles/unittest/1tet.g
>   MOAB/trunk/MeshFiles/unittest/3k-tri-cube.h5m
>   MOAB/trunk/MeshFiles/unittest/3k-tri-sphere.vtk
>   MOAB/trunk/MeshFiles/unittest/4k-tri-plane.vtk
>   MOAB/trunk/MeshFiles/unittest/4tet.g
>   MOAB/trunk/MeshFiles/unittest/64bricks_512hex.h5m
>   MOAB/trunk/MeshFiles/unittest/8hex.g
>   MOAB/trunk/MeshFiles/unittest/cell1.gen.gz
>   MOAB/trunk/MeshFiles/unittest/cell2.gen.gz
>   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.1.cub
>   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.2.cub
>   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.cub
>   MOAB/trunk/MeshFiles/unittest/io/cube.sms
>   MOAB/trunk/MeshFiles/unittest/io/gmsh2.msh
>   MOAB/trunk/MeshFiles/unittest/io/ho_test.cub
>   MOAB/trunk/MeshFiles/unittest/io/ho_test.g
>   MOAB/trunk/MeshFiles/unittest/io/sample.stl
>   MOAB/trunk/MeshFiles/unittest/io/test.cub
>   MOAB/trunk/MeshFiles/unittest/io/test.nas
>   MOAB/trunk/MeshFiles/unittest/io/test.unv
>   MOAB/trunk/MeshFiles/unittest/io/three.smf
>   MOAB/trunk/MeshFiles/unittest/mb_big_test.g.gz
>   MOAB/trunk/MeshFiles/unittest/mbtest1.g
>   MOAB/trunk/MeshFiles/unittest/mbtest2.g
>   MOAB/trunk/MeshFiles/unittest/mbtest3.g
>   MOAB/trunk/MeshFiles/unittest/ptest.cub
>   MOAB/trunk/MeshFiles/unittest/test.g
>   MOAB/trunk/MeshFiles/unittest/testquad-cyl.g
>   MOAB/trunk/MeshFiles/unittest/testquad.g
>   MOAB/trunk/MeshFiles/unittest/testtet.g
> Removed:
>   MOAB/trunk/test/125hex.g
>   MOAB/trunk/test/1hex.g
>   MOAB/trunk/test/1khex.g
>   MOAB/trunk/test/1tet.g
>   MOAB/trunk/test/3k-tri-cube.h5m
>   MOAB/trunk/test/3k-tri-sphere.vtk
>   MOAB/trunk/test/4k-tri-plane.vtk
>   MOAB/trunk/test/4tet.g
>   MOAB/trunk/test/8hex.g
>   MOAB/trunk/test/cell1.gen.gz
>   MOAB/trunk/test/cell2.gen.gz
>   MOAB/trunk/test/cube.sms
>   MOAB/trunk/test/io/brick_cubit10.1.cub
>   MOAB/trunk/test/io/brick_cubit10.2.cub
>   MOAB/trunk/test/io/brick_cubit10.cub
>   MOAB/trunk/test/io/gmsh2.msh
>   MOAB/trunk/test/io/ho_test.cub
>   MOAB/trunk/test/io/ho_test.g
>   MOAB/trunk/test/io/sample.stl
>   MOAB/trunk/test/io/test.cub
>   MOAB/trunk/test/io/test.nas
>   MOAB/trunk/test/io/test.unv
>   MOAB/trunk/test/io/three.smf
>   MOAB/trunk/test/mb_big_test.g.gz
>   MOAB/trunk/test/mbtest1.g
>   MOAB/trunk/test/mbtest2.g
>   MOAB/trunk/test/mbtest3.g
>   MOAB/trunk/test/parallel/64bricks_512hex.h5m
>   MOAB/trunk/test/parallel/ptest.cub
>   MOAB/trunk/test/test.g
>   MOAB/trunk/test/testquad-cyl.g
>   MOAB/trunk/test/testquad.g
>   MOAB/trunk/test/testtet.g
> Log:
> Now moving the various mesh files.
> Copied: MOAB/trunk/MeshFiles/unittest/125hex.g (from rev 3917, MOAB/
> trunk/test/125hex.g)
> (Binary files differ)
> Copied: MOAB/trunk/MeshFiles/unittest/1hex.g (from rev 3917, MOAB/
> trunk/test/1hex.g)
> Copied: MOAB/trunk/MeshFiles/unittest/1khex.g (from rev 3917, MOAB/
> trunk/test/1khex.g)
> Copied: MOAB/trunk/MeshFiles/unittest/1tet.g (from rev 3917, MOAB/
> trunk/test/1tet.g)
> Copied: MOAB/trunk/MeshFiles/unittest/3k-tri-cube.h5m (from rev
> 3917, MOAB/trunk/test/3k-tri-cube.h5m)
> Copied: MOAB/trunk/MeshFiles/unittest/3k-tri-sphere.vtk (from rev
> 3917, MOAB/trunk/test/3k-tri-sphere.vtk)
> --- MOAB/trunk/MeshFiles/unittest/3k-tri-
> sphere.vtk	                        (rev 0)
> +++ MOAB/trunk/MeshFiles/unittest/3k-tri-sphere.vtk	2010-05-19
> 16:06:47 UTC (rev 3919)
> @@ -0,0 +1,7434 @@
> +# vtk DataFile Version 2.0
> +MOAB Version 1.01
> +ASCII
> +DATASET UNSTRUCTURED_GRID
> +POINTS 1487 double
> +0 0 100
> +0 0 -100
> +9.98334 0 99.5004
> +9.98334 0 -99.5004
> +4.99167 8.64583 99.5004
> +4.99167 8.64583 -99.5004
> +-4.99167 8.64583 99.5004
> +-4.99167 8.64583 -99.5004
> +-9.98334 5.88811e-09 99.5004
> +-9.98334 5.88811e-09 -99.5004
> +-4.99167 -8.64583 99.5004
> +-4.99167 -8.64583 -99.5004
> +4.99167 -8.64583 99.5004
> +4.99167 -8.64583 -99.5004
> +-1.37122 98.5865 -16.6977
> +-9.74601 98.3925 -14.9644
> +-20.5671 96.856 -13.9968
> +-30.3772 94.7213 -10.2522
> +-38.9169 91.8629 -6.83257
> +-46.4351 88.5345 -2.3288
> +97.8148 20.331 -4.34927
