[MOAB-dev] r3919 - in MOAB/trunk: MeshFiles/unittest	MeshFiles/unittest/io test test/io test/parallel
    tautges at mcs.anl.gov
    Wed May 19 11:06:47 CDT 2010
Author: tautges
Date: 2010-05-19 11:06:47 -0500 (Wed, 19 May 2010)
New Revision: 3919
Added:
   MOAB/trunk/MeshFiles/unittest/125hex.g
   MOAB/trunk/MeshFiles/unittest/1hex.g
   MOAB/trunk/MeshFiles/unittest/1khex.g
   MOAB/trunk/MeshFiles/unittest/1tet.g
   MOAB/trunk/MeshFiles/unittest/3k-tri-cube.h5m
   MOAB/trunk/MeshFiles/unittest/3k-tri-sphere.vtk
   MOAB/trunk/MeshFiles/unittest/4k-tri-plane.vtk
   MOAB/trunk/MeshFiles/unittest/4tet.g
   MOAB/trunk/MeshFiles/unittest/64bricks_512hex.h5m
   MOAB/trunk/MeshFiles/unittest/8hex.g
   MOAB/trunk/MeshFiles/unittest/cell1.gen.gz
   MOAB/trunk/MeshFiles/unittest/cell2.gen.gz
   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.1.cub
   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.2.cub
   MOAB/trunk/MeshFiles/unittest/io/brick_cubit10.cub
   MOAB/trunk/MeshFiles/unittest/io/cube.sms
   MOAB/trunk/MeshFiles/unittest/io/gmsh2.msh
   MOAB/trunk/MeshFiles/unittest/io/ho_test.cub
   MOAB/trunk/MeshFiles/unittest/io/ho_test.g
   MOAB/trunk/MeshFiles/unittest/io/sample.stl
   MOAB/trunk/MeshFiles/unittest/io/test.cub
   MOAB/trunk/MeshFiles/unittest/io/test.nas
   MOAB/trunk/MeshFiles/unittest/io/test.unv
   MOAB/trunk/MeshFiles/unittest/io/three.smf
   MOAB/trunk/MeshFiles/unittest/mb_big_test.g.gz
   MOAB/trunk/MeshFiles/unittest/mbtest1.g
   MOAB/trunk/MeshFiles/unittest/mbtest2.g
   MOAB/trunk/MeshFiles/unittest/mbtest3.g
   MOAB/trunk/MeshFiles/unittest/ptest.cub
   MOAB/trunk/MeshFiles/unittest/test.g
   MOAB/trunk/MeshFiles/unittest/testquad-cyl.g
   MOAB/trunk/MeshFiles/unittest/testquad.g
   MOAB/trunk/MeshFiles/unittest/testtet.g
Removed:
   MOAB/trunk/test/125hex.g
   MOAB/trunk/test/1hex.g
   MOAB/trunk/test/1khex.g
   MOAB/trunk/test/1tet.g
   MOAB/trunk/test/3k-tri-cube.h5m
   MOAB/trunk/test/3k-tri-sphere.vtk
   MOAB/trunk/test/4k-tri-plane.vtk
   MOAB/trunk/test/4tet.g
   MOAB/trunk/test/8hex.g
   MOAB/trunk/test/cell1.gen.gz
   MOAB/trunk/test/cell2.gen.gz
   MOAB/trunk/test/cube.sms
   MOAB/trunk/test/io/brick_cubit10.1.cub
   MOAB/trunk/test/io/brick_cubit10.2.cub
   MOAB/trunk/test/io/brick_cubit10.cub
   MOAB/trunk/test/io/gmsh2.msh
   MOAB/trunk/test/io/ho_test.cub
   MOAB/trunk/test/io/ho_test.g
   MOAB/trunk/test/io/sample.stl
   MOAB/trunk/test/io/test.cub
   MOAB/trunk/test/io/test.nas
   MOAB/trunk/test/io/test.unv
   MOAB/trunk/test/io/three.smf
   MOAB/trunk/test/mb_big_test.g.gz
   MOAB/trunk/test/mbtest1.g
   MOAB/trunk/test/mbtest2.g
   MOAB/trunk/test/mbtest3.g
   MOAB/trunk/test/parallel/64bricks_512hex.h5m
   MOAB/trunk/test/parallel/ptest.cub
   MOAB/trunk/test/test.g
   MOAB/trunk/test/testquad-cyl.g
   MOAB/trunk/test/testquad.g
   MOAB/trunk/test/testtet.g
Log:
Now moving the various mesh files.
Copied: MOAB/trunk/MeshFiles/unittest/125hex.g (from rev 3917, MOAB/trunk/test/125hex.g)
(Binary files differ)
Copied: MOAB/trunk/MeshFiles/unittest/1hex.g (from rev 3917, MOAB/trunk/test/1hex.g)
Copied: MOAB/trunk/MeshFiles/unittest/1khex.g (from rev 3917, MOAB/trunk/test/1khex.g)
Copied: MOAB/trunk/MeshFiles/unittest/1tet.g (from rev 3917, MOAB/trunk/test/1tet.g)
Copied: MOAB/trunk/MeshFiles/unittest/3k-tri-cube.h5m (from rev 3917, MOAB/trunk/test/3k-tri-cube.h5m)
Copied: MOAB/trunk/MeshFiles/unittest/3k-tri-sphere.vtk (from rev 3917, MOAB/trunk/test/3k-tri-sphere.vtk)
--- MOAB/trunk/MeshFiles/unittest/3k-tri-sphere.vtk	                        (rev 0)
+++ MOAB/trunk/MeshFiles/unittest/3k-tri-sphere.vtk	2010-05-19 16:06:47 UTC (rev 3919)
@@ -0,0 +1,7434 @@
+# vtk DataFile Version 2.0
+MOAB Version 1.01
+ASCII
+DATASET UNSTRUCTURED_GRID
+POINTS 1487 double
+0 0 100
+0 0 -100
+9.98334 0 99.5004
+9.98334 0 -99.5004
+4.99167 8.64583 99.5004
+4.99167 8.64583 -99.5004
+-4.99167 8.64583 99.5004
+-4.99167 8.64583 -99.5004
+-9.98334 5.88811e-09 99.5004
+-9.98334 5.88811e-09 -99.5004
+-4.99167 -8.64583 99.5004
+-4.99167 -8.64583 -99.5004
+4.99167 -8.64583 99.5004
+4.99167 -8.64583 -99.5004
+-1.37122 98.5865 -16.6977
+-9.74601 98.3925 -14.9644
+-20.5671 96.856 -13.9968
+-30.3772 94.7213 -10.2522
+-38.9169 91.8629 -6.83257
+-46.4351 88.5345 -2.3288
+97.8148 20.331 -4.34927
