[MOAB-dev] error in mbsize and problem using debugger
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Wed May 19 15:05:16 CDT 2010
Rajeev Jain wrote:
> Another thing is I'm unable use ddd even after using --enable-debug option.
> This is the message on the screen
> "/nfs/mcs-homes139/jain/MOAB/tools/mbsize": not in executable format:
> File format not recognized
> jain at jain-desktop:~/MOAB/tools$ file mbsize
> mbsize: POSIX shell script text executable
If you compile MOAB as a shared library than all of the tools will be shell
scripts that set LD_LIBRARY_PATH correctly.  You can a) build as a static
library, b) use the actual executable, which is probably hidden .libs/, or
c) do 'make install' and debug the installed version.
- jason
